help connecting two monitors?!?!?
Solved by Totalschaden1997,
Most of the time the iGPU is disabled when you plug in a real GPU.
You can change it in the BIOS tho.
But you only get the performance of the iGPU on the second monitor.
(You might want to get a HDMI --> DVI cable)
Featured Topics
mrtwonavels ·
Scitesh ·
Posted in Troubleshooting0 -
OllyOllyOxycontin ·
4
4
ImTehCookie ·
Posted in Networking0 -
Worstcaster ·
Posted in New Builds and Planning1 -
