its fine. the cmos battery needs to last a long time, so motherboard manufacturers make sure its power doesnt reach anything more than it needs to.
if it was a problem, motherboards wouldnt ship with the battery installed.
https://linustechtips.com/topic/492616-remove-cmos-battery/#findComment-6602677
Nope.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/492616-remove-cmos-battery/#findComment-6602679
do i need to remove cmos / motherboard battery to change hardware such as RAM, GPU, CPU etc?
No you can keep it in while doing that, if you remove it, it's the old fashion way of clearing the CMOS if you don't have a button on the motherboard.
https://linustechtips.com/topic/492616-remove-cmos-battery/#findComment-6602681
If you have set XMP for RAM or some OC for CPU, you need to load default settings on boot. UEFI mobos can do that without clearing CMOS. Older mobos might require clearing CMOS, but you can do that without removing battery itself.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/492616-remove-cmos-battery/#findComment-6604103
