Context?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/492263-pcie-running-at-x/#findComment-6598930
what is this?
it says PCIexpress x16 slot  running at x16
or running at x4
Are you looking at motherboards or software?
On motherboards it means it's an x4 slot, but they stuck an x16-size socket onto it to make it look like an x16 slot.
In software readings it means the PCIe slot is operating at a lower mode to save power when the full bandwidth isn't required.
https://linustechtips.com/topic/492263-pcie-running-at-x/#findComment-6598937
yes, mobo's
so, is that bad for performance? I'm going to crossfire, that's why I'm asking
https://linustechtips.com/topic/492263-pcie-running-at-x/#findComment-6598954
No, doesn't matter. crossfire is happy with that.
especially with new gpu's and motherboard that both support PCI-E 3.0. Won't have any impact at all.
It means the bandwidth that's available.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/492263-pcie-running-at-x/#findComment-6598964
oops.
motherboards
PCIe sockets
I know you're talking about MOBO' s, but where does it say that?
https://linustechtips.com/topic/492263-pcie-running-at-x/#findComment-6598974
If it's PCI Express 3.0, no it shouldn't be a problem.
so, if it's 2.0 it has impact, but on 3.0 not?
at "slots"
https://linustechtips.com/topic/492263-pcie-running-at-x/#findComment-6598992
2.0 4X, yes it will have an impact, like 10%... Not much and not enough to worry.
No reason to be scared, just go 4 it and you will be fine!
I had a 2nd gpu running at 4x with pci-e 2.0 and never saw issues related to it having only 4x.
https://linustechtips.com/topic/492263-pcie-running-at-x/#findComment-6599014
at "slots"
In your MOBO's manual? Or what?
https://linustechtips.com/topic/492263-pcie-running-at-x/#findComment-6599020
okay, that's nice to hear
thanks
https://linustechtips.com/topic/492263-pcie-running-at-x/#findComment-6599051
