I would like better sound quality for both my mic and my headset, I have a Triton Kunai headset and an Audio Technica ATR2100 USB mic. any reccomendations?
What is your budget?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/491493-best-sound-card/#findComment-6589405
Might be able to get a decent Asus STX 2nd hand for a bit less than that, but it is a bit much for those headphones. A new Asus Xonar DX might do, and with 7.1 as an option it means if you ever want to use speakers (or do already) you can get a sweet surround setup :)
https://linustechtips.com/topic/491493-best-sound-card/#findComment-6589487
You won't be getting better sound from that headset, it is a cheaply built, over-marketed headset just like the rest of the gaming brands out there (Razer, Astro, Triton, Psyko, MadCatz, TurtleBeach, Plantronics, etc.). If you want better sound quality, get a quality headset or more preferable, headphones.
Since you have a USB mic, I don't see a reason for a headset. So take a look at the Creative Aurvana Live!, Takstar Pro80, and NVX XPT100 for $100 and under.
MSI Z97M Gaming | i7-4790k | NZXT Kraken X61 | 16GB Kingston Savage DDR3 2400
EVGA GTX1080 Ti FTW3 | EVGA G2 750 | Phanteks Enthoo Evolv | 1TB 850 Evo | 2TB 860 Evo | 22TB DS918+
Scarlett 2i2 | WooAudio WA7 Fireflies | Fostex TR-X00 | Beyer DT990 | MrSpeaker Alpha Dog | V-Moda M-100 | JBL LSR305 MK2
https://linustechtips.com/topic/491493-best-sound-card/#findComment-6590739
