80+ Power Supplies
Go to solution Solved by Oshino Shinobu,
so it's basically how much power is being pulled from the wall
In relation to the power being used by the system, yes.
So, a normal 80+ PSU at 50% load (lets say 500W again) is going to be pulling 600W from the wall. A Gold rated PSU is going to be pulling 550W from the wall in the same conditions.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/490187-80-power-supplies/#findComment-6574173
what does the 80+ rating on power supplies stand for?
Guide in my sig. Also pinned on the PSU and cases subforum
https://linustechtips.com/topic/490187-80-power-supplies/#findComment-6574215
like how much efficient the usage of electricity is ?
Yes. So, if your system is using 500W, the 80+ rating will determine how much your system is going to be pulling from the wall. At 100% efficiency, a PSU would pull 500W from the wall.
For this table, if 500W is 50% load on a gold rated PSU, then it is 90% efficient. This means that it is going to be pulling 10% more from the wall than the system is using, so around 550W from the wall.
That's my understanding of it.
Basically, the better the efficiency, the cheaper it is going to be to run. It doesn't necessarily relate to the PSU's quality though.
https://linustechtips.com/topic/490187-80-power-supplies/#findComment-6574229
https://linustechtips.com/topic/490187-80-power-supplies/#findComment-6574247
https://linustechtips.com/topic/490187-80-power-supplies/#findComment-6574272
