Hello, so my graphics card is sagging, I saw this video (linked below) where he used a pencil to keep his Gpu up. I tried doing this but the only way to do it is for the pencil's end to be sitting on my 24pin motherboard power cable near the psu, I have a cx500 psu ( yes I know it sucks, new one on the way) and the cable is wrapped, could this cause a fire hazard?
https://linustechtips.com/topic/490108-fire-hazard-gpu-sag/
as long as you keep the pencil on the connector instead of the actual cables it should be fine.
it's still a pretty bad idea tough. you're putting a lot of extra stress on the connector this way. you'll be replacing the PSU soon tough so i guess it shouldn;t really matter
https://linustechtips.com/topic/490108-fire-hazard-gpu-sag/#findComment-6573335
nope its safe
just dont use a sharpened pencil :P
https://linustechtips.com/topic/490108-fire-hazard-gpu-sag/#findComment-6573337
Did you screw the GPU in first?
CPU: Intel i5 4690k @ 4.3 GHz       GPU: MSI GTX 980                      Cooling: be quiet! Pure Rock                     OS: Windows 7            Monitor: BenQ XL2411Z
Motherboard: AsRock Z97 PRO4   PSU: Corsair 600W CX600M       Keyboard: Razer BlackWidow Ultimate   SSD: Intel 120GB 520   Headset: HyperX Cloud II
RAM: 12GB Crucial Ballistix            Case: Corsair 750D                       Mouse: Logitech G502                         HDD: Seagate 1TB        Speakers: Audioengine A5+
https://linustechtips.com/topic/490108-fire-hazard-gpu-sag/#findComment-6573357
Zip ties to keep the Gpu from sagging?
Btw can the Gpu sag cause damage?
Yep. hang the card, rather than supporting it from the bottom.
It can do in some cases. It sort of depends on the weight of the card, as if it's too heavy, it can damage the PCIe connector.
https://linustechtips.com/topic/490108-fire-hazard-gpu-sag/#findComment-6573379
You could get some string or something similar and wrap it around the PCIe power cable and the top of you case, tighten it until you GPU doesn't sag heaps and it should be all good. Even if it is sagging it won't be a big deal unless it is something crazy like falling out of the PCIe lane, which should happen anyway because of the locks.
Edit - Something like this I suppose.
4790k @ 4.5Ghz 1.180v NZXT Kraken X31 | MSI Z97 Krait | Kingston Hyper X Fury 32GB 1866Mhz, 2 DIMMs white and 2 black | GTX 980 Ti - G1 Gaming | GTX 680 - Reference | SilverStone ST75F-P | Phanteks Enthoo Pro
https://linustechtips.com/topic/490108-fire-hazard-gpu-sag/#findComment-6573391
