So I've crossfired my cards and I'm getting less FPS than before, I'm not quite sure what it is, I have an 850W platinum PSU, AMD FX-8320, and a ASUSTeK COMPUTER INC. M5A97 R2.0 motherboard.
Some games don't support crossfire, and cross firing can sometimes cause trouble with said game, causing fps to drop.
First, make sure you have uninstalled and reinstalled the drivers and Catalyst. Always restart the PC when going enabling or disabling crossfire. In the gaming menu under 3D options go to the bottom and select the profile for the game you're playing. Usually easier to use the search bar directly over the list. Hope that helps
If anyone asks you never saw me.
I've done the drivers several times, and I don't see a profile for any game in 3D settings.
All the way at the bottom. You'll see the crossfire profile set to default. Select that and choose, says something about game profile(away from my rig), then you get the option to choose a specific profile. It's harder than it should be and hopefully Crimson fixes this. But it's there at the bottom. And make a separate profile in Catalyst for each game you play so you don't have to do this every time to play. In the 3D menu you'll see a + sign to the left between the two menus. Hit the plus sign and open the exe launcher for the game you want to create a menu for. Then each time you play Catalist will use those settings automatically
http://imgur.com/8GPw4Fi Like this
Question - is your motherboard equipped with 2 PCIe 2.0 X16 slots? If no - that's your issue
Is there a way to check?
the 8320 is a pretty old cpu for now, reccomended gpu to use with are up to a 960/380/380x/280x, there are little bottlenecks when using r9 290 /390 -gtz 970or better
if you are using 2 r9 280x, there will be most likely a bottleneck. Try overclocking your cpu a little. if you see a perfromance increase, the 2 gpus are getting bottlenecked
The site has changed....
Depends on the game. You can set the cores used with Fallout 4 and this allows the 8320 to perform better than a 4690k. Don't fall for the trap of all or nothing. It's game to game, task to task.
There are just 280s, not 280xs and ill try that too.
well, that is true, but only for well optimized games that can utilize all cores. Most games cant, but things seem to change
And I'm also going to overclock my CPU some and see if that helps. Also is it normal for my second GPUs activity to be at 0%
Depends, could mean Xfire isn't enabled or that the second GPU isn't needed. If you have a max fps set then Catalyst will turn off the second GPU when you hit it.
Its enabled and I don't have the FPS cap on.
What resolution is your monitor and do you use Steam. If 1080p and yes then Steam will limit you to 60fps and Catalyst will respond by shutting down the second GPU. The second GPU should kick in instantly to deal with fps dips, If the profile is a good one.
yeah it's 1080
yeah it's 1080
Try a game outside of Steam if you have one. It's academic though as if it's a 60hz monitor everything over 60fps is a waste. Only thing to watch for is dips below 60 and in crossfire you shouldn't see them unless you're playing something like Fallout 4.
