Anyone have a really detailed guide of advanced things you can do to improve the note edge battery life, performance, and all that jazz?
Other than rooting or opening dev options and turning down window animation I don't know any other things to do, nor can I find any.
CPU -  Intel i7 4770k 4.6Ghz     Motherboard - MSI GD-65    RAM - Corsair Vengeance 16 GB     GPU - XFX 295x2    Case - NZXT H440
Storage - 256GB OCZ Vertex 4 ssd, 1TB WD Blue 7200rpm    PSU -  EVGA SuperNOVA 850 G2  Cooling - Corsair H80i     Keyboard - KGParadise v60 w/ cherry mx greens
Mouse -Theron  Sound - HyperX Cloud
https://linustechtips.com/topic/488698-note-edge-maximize-performance/
You can alter the animations in the developer options. That'll make it feel snappier.
I've had mixed luck with BatteryDefender for saving battery. Other than that, just turn off certain apps from syncing if you're having issues.
Do you actually need more performance out of the phone?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Not necessarily performance, more concerned about extending battery life. But all those battery "saving" apps seem be counter-productive if anything
What kind of screen on time are you seeing?
ULTRA POWER SAVING MODE YAY
custom rom support for note edge is shit
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
