I currently have an Asus DirectCU R9-290 and I was wondering if it would be worth it to buy another 290 for Crossfire. I'm just worried about how well Crossfire will work on games. The only games I'm playing right now are Fallout 4, Final Fantasy 3 and 14, Audiosurf, and ya, that's pretty much it for now. I know Crossfire would only be worth it for Fallout 4 from that list, haha. So ya, how well does Crossfire work, and for the games that it doesn't really work with, can I disable it without having to remove the card?
COMIC SANS
https://linustechtips.com/topic/488660-how-well-does-crossfire-work/
Fallout 4 is easy to run so you wouldn't actually be utilizing it, unless you plan to run games at ultra @ 144Hz or Ultrawide 1440p.
Why not both? :D
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
micro stuttering still exists, unfortunately
correction,
how well does a given game support crossfire.
it varies, but in most games you will see anywhere from 70-80% increase to performance
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
Why not both? :D
Really though, since you already have one 290 I'd say its worth it
Crossfire is generally supported or can be manually setup, and you usually see slightly less than double the performance scaling in most games
Doesn't matter if you have 980ti SLI or Titan X Sli, they all bow down to the "Shadow distance" settings in Fallout 4.
I'd say challenge accepted, but I don't own Fallout 4 so I can't test it.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
