CAD $2000 Build
Go to solution Solved by TheRandomness,
@144hz Better for your money build imo. (Are you sure you don't need large capacity storage?)
CPU Cooler: Cooler Master Seidon 120V 86.2 CFM Liquid CPU Cooler  ($68.98 @ Newegg Canada)
Motherboard: Gigabyte GA-Z170M-D3H Micro ATX LGA1151 Motherboard  ($110.99 @ Newegg Canada)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($105.98 @ Newegg Canada)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($429.98 @ Newegg Canada)
Case: Thermaltake Core V21 MicroATX Mini Tower Case  ($75.59 @ DirectCanada)
Monitor: BenQ XL2411Z 144Hz 24.0" Monitor  ($299.99 @ NCIX)
Keyboard: Razer BlackWidow Ultimate 2016 Wired Standard Keyboard  ($143.63 @ Newegg Canada)
Speakers: Logitech Z313 25W 2.1ch Speakers  ($58.99 @ DirectCanada)
Total: $1851.52
Generated by PCPartPicker 2015-11-20 11:03 EST-0500
R9 390 > 970
https://linustechtips.com/topic/488584-cad-2000-build/#findComment-6557191
R9 390 > 970
Would he not be better with a Quadro anyway?
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/488584-cad-2000-build/#findComment-6557200
I apologize if this is posted in the wrong place.
So, within November I am ordering a new computer and should be around CAD $2000 with tax.
This is what I have so far. I just wanted a second look with everyone and find out what changes should be made.
Welcome to the forum!
Like @don_svetlio said, an R9 390 is a better option.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/488584-cad-2000-build/#findComment-6557208
If he's doing work with it yes.
https://linustechtips.com/topic/488584-cad-2000-build/#findComment-6557210
I would go with the Quadro as well. Its a work PC graphics card and not enthusiast grade.
Also if you can bump that 6600 to a 6700 you would get i7 performance and small boost in clock speed. But thats just me.
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
https://linustechtips.com/topic/488584-cad-2000-build/#findComment-6557224
Well... it is a CAD build.
https://linustechtips.com/topic/488584-cad-2000-build/#findComment-6557237
He means CAD as in the currency, not the programs :P
oh.. lol. Hahahahaha  :lol:  :lol:
https://linustechtips.com/topic/488584-cad-2000-build/#findComment-6557242
CAD = canadian dollar :P
https://linustechtips.com/topic/488584-cad-2000-build/#findComment-6557258
Total: $1851.52
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/488584-cad-2000-build/#findComment-6557268
Total: $1851.52
will do, if I ran out of memory I would use the HDD on my current PC.
https://linustechtips.com/topic/488584-cad-2000-build/#findComment-6557301
