Bottom right of the motherboard. I have the same one.
CPU: Intel I7 4790k @ 4.6Ghz 1.255v | GPU: Gigabyte G1 Gaming GTX 980 Ti | Display: Acer XB270HU bprz | RAM: 16GB (4x4GB) Gskill Ripjaws X 1866MHz | CPU Cooler: H80i | Motherboard: MSI Z97 Gaming 5 | SSD: Mushkin 120GB + Sandisk 480GB | HDD: WD Blue 1TB | Case: Enthoo Pro |PSU: Seaconic M12II EVO 850w | OS: Windows 10 64-Bit | Mouse: Logitech RGB G502 | Keyboard: Thermaltake Poseidon Z (Brown Switches) |
https://linustechtips.com/topic/488548-my-friend-needs-help-now/#findComment-6556722
Case: NZXT h440
MB: http://imgur.com/oWX74pK
Where to connect a connectors of the case like: power, restart... ETC
We have no idea and we need helpppp
The bottom right of the motherboard is where you connect those things are the connectors should be inside the case.
https://linustechtips.com/topic/488548-my-friend-needs-help-now/#findComment-6556726
case:"accelerated"Therlmatake VA8000BWS Armor psu:EVGA Supernova G2 750w board:Asus M5A99 FX Pro R.2
cpu:AMD FX 8350 ram:2x8gb Corsair Vengeance Pro 1866mhz gpu:Sapphire Nitro R9 380  4gb
ssd:Samsung 850 EVO 250gb hdd: 2x1tb WD Caviar green cpu cooler: Coolermaster Hyper 212 EVO
https://linustechtips.com/topic/488548-my-friend-needs-help-now/#findComment-6556766
yeah they are there but which one is for what?
MSI includes a small connector/jumper that has labeled connections on it so that you can use to plug all the case cables into it and then that connector into the motherboard.
https://linustechtips.com/topic/488548-my-friend-needs-help-now/#findComment-6556788
