So to start off I am very new to building pcs (I have been an xbox gamer for a while), this will be my first build so please correct me on anything I get wrong... So I am looking to build a pc for 1440p gaming at high settings. I think the most taxing thing I plan on doing with it is playing skyrim with some very nice texture and lighting mods. The build that I currently set up is this http://pcpartpicker.com/p/x3v3P6 but I have some worries. First off I went with the 980 ti since I want to max things out at 1440p and the benchmarks seemed to indicate that was the way to go. I realized for a similar price i could crossfire two 390s or two 290xs would either of these be better options especially considering the 390's 8gb of vram for the future (and yes I know crossfire wont increase my vram). I am also worried about my cpu bottlenecking my card, will the i5 4960k be enough? I would appreciate really any feedback on this.
ps. This is an aside and note but should I be buying a mobo and cpu with an LGA1151 socket instead so that I can upgrade in the future? Thanks! :)
Oh and my budget is around <$2000
https://linustechtips.com/topic/488300-graphics-card-for-1440p/
stick with the 980Ti
Crossfire 390 or 290X are nice to have but they are a pain if the games dont support CrossFire
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/488300-graphics-card-for-1440p/#findComment-6553463
The 980ti is the correct choice, never crossfire/sli cards when 1 card can win the day, also that psu is kinda crap
https://pcpartpicker.com/part/xfx-power-supply-p1750gts3x here's a replacement @SirStabalot
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
https://linustechtips.com/topic/488300-graphics-card-for-1440p/#findComment-6553474
