Hello Everyone, just wanna ask what is the reason behind opening Multiple Tabs in my browser like 50 tabs on it, then it's just don't seem to be working well. I feel like there's something wrong with it. probably like non-responsiveness and lagging. I Just wanna know what made this kind of problem. need a little help here. I don't know is it the hardware or kinda internet speed, maybe? I'm not sure, I need your thoughts guys.
~Thanks Linustechtips
https://linustechtips.com/topic/487255-multiple-tabs-on-a-browser-problem/
SNIP
You mean it gets slow when you open 50 tabs? thats normal every tab uses RAM, and the more tabs open, the more RAM you use until its full then it will just get slower and slower
Your CPU and RAM, and your HDD at launch cos the browser needs to read your Cache and reload all those tabs.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
Who has 50 tabs open at once? I only keep as many open as I can read the headers of.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
I used HyperX 1600mhz 16GB Ram and a Core I7 4790K  by the way.
Ok?... why do you have 50 tabs open? it will use up all your ram
a month ago i had like 80 tabs open(deviantart youtube etc) and firefox only used 4gb of my ram :D
the usage depends on the loaded sites too, 16gb ram should be able to open more than 50tabs
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
True it should, but it depends what is open, is it 50 forums tabs, or like 50 tabs of 4k video
while working I split the screen and sometimes I'm streaming live and watch movies while working. my job is to communicate with the client.like a online service center
And that's only some of the chrome.exe applications.
Chrome eats up RAM. If you have 50 tabs open at a average of 80,000K(80MB's) that's 4GB's!
That's with the assumption that everything is 80MB's
There are some pages that eat up 150+ MB's of ram.
I'm using 764MB;s with only 10 tabs open.
Chrome is also more of a memory hog than the others btw, so see if you have the same problem when switching browsers.
Corsair 900D | Gigabyte SOC Champion X99 | EVGA 980ti SLI | 4x4Gb Kingston 2666 | dual custom loop | Intel 5960x | Corsair Ax1500i
Samsung 850 EVO 500Gb | Acer XB270HU
Oh and check if any of the tabs you have open are heavy html5 pages. My browser struggles for a while when I first open the robertspaceindustries.com page
I got two suggestion for fix. One is to try with another browser. Chrome is one known to be memory hog, Firefox has issues in flash content in general. Another is to set tabs to load only when you activate them.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
