So basically i play on a acer laptop and have got pretty good into pc gameing and decited it was time to make an upgrade. I have a budget, but that can be adjusted, and i have put something together so let me know what u think but dont blow up the comments with nerdy crap PLS
PC Build: http://ca.pcpartpicker.com/p/VCGs23
Keyboard: http://www.razerzone.com/ca-en/store/razer-blackwidow-chroma
Monitor: http://www.amazon.ca/gp/product/B007HSKSMI?keywords=monitor&qid=1445303531&ref_=sr_1_2&sr=8-2
Wifi Stick: http://www.newegg.ca/Product/Product.aspx?Item=N82E16833320074
https://linustechtips.com/topic/486390-kinda-a-noob-need-some-help/
Switch out the CX PSU for an EVGA one.
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
Motherboard: Gigabyte GA-B150M-D3H Micro ATX LGA1151 Motherboard  ($109.99 @ NCIX)
Video Card: MSI Radeon R7 370 4GB Video Card  ($218.01 @ Vuugo)
Case: Corsair 200R ATX Mid Tower Case  ($74.95 @ Vuugo)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($79.98 @ Newegg Canada)
Total: $785.92
Generated by PCPartPicker 2015-11-16 22:52 EST-0500
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
