So, I want to buy a core i5 4460, and im just asking for the heck of it but will four pin pwoer be fine for it? It is in the mobo compatibility list however the mobo only has 4 pin power. I want to make sure this will work. I plan on gaming and the most CPU intensive game is either far cry 4 (or primal once its out), or Battlefield 4, I dont want to edit videos or do stress tests or anything.
H81M - e33 mobo
430W power supply
r7 250 GPU (will upgrade)
8GB DDr3
Thanks!
https://linustechtips.com/topic/486232-4-pin-power/
H81M - e33 mobo
430W power supply
8GB DDr3
Thanks!
Like Austins extremely cringe worthy of trying to get an 8 pin EPU power on the Scrap Yard Wars video... A a 4 pin is WAY more than enough power
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/486232-4-pin-power/#findComment-6525103
H81M - e33 mobo
430W power supply
8GB DDr3
Thanks!
The PSU is CX430? I would change it first. Then you can get the 380/390
https://linustechtips.com/topic/486232-4-pin-power/#findComment-6525110
No need to worry. (I guess you've watched Scrapyard Wars)
The 4 pin power connector will be just fine.
https://linustechtips.com/topic/486232-4-pin-power/#findComment-6525159
You can use 4 pin cable in a 8 pin connector, just make sure you plug it in the right way(unlike Austin in scrapyard wars). Out of the 8 pins, it should only fit in one side of the connector.
https://linustechtips.com/topic/486232-4-pin-power/#findComment-6525239
