hello you lovely people of the internet. i recently bought a gaming pc and since i bought it i have not really got the game i want to run properly. majorly when i booted up the amazing fallout 4 for the first a giddy as a child on Christmas i was met with a few issues which have plague my short time playing pc games. in a number of game such as mad max  bf4 and fallout i have been experiencing a few issues in regards to frame drops. i will be happily playing along at 60 fps then receive a massive drop in fps sometimes to as low as 20 fps. this continues to happen even when i turn the settings of the games right down. for example my pc was automatically set to ultra settings for fallout and when i dropped them to medium and turning of some effects i still got the same problem, not as bad but defiantly still there. the game will run fine in an area if i stand still on not move much but the second i try to wonder into the depths of the wasteland bye bye frame rate this happens regardless of settings. so can anyone help me to resolve my issue as i really wanna play fallout i just want decent graphics and a consistent frame rate be that 30 or 60 fps.
my rig:
  • Sharkoon Bulldozer Black/Red Mid Tower Gaming Case
  • AMD FX-8350 4.00GHz (4.20GHz Turbo) 8x Core Processor - Unlocked
  • Gigabyte GA-970A-DS3P AMD 970 ATX Motherboard
  • 16GB (2x8GB) Corsair Vengeance Jet Black Low Profile 1600MHz CL10 DDR3 Dual/Quad Channel Kit [CML16GX3M2A1600C10]
  • Sapphire Radeon NITRO R9 390 Tri X OC AMD Graphics Card 8GB
  • 24x LiteOn Internal DVD-RW Drive
  • 1TB Seagate Barracuda SATA III Hard Drive
  • Thermaltake Contac 21 CPU Air Cooler
  • Corsair CS750M CS Modular 80 Plus GOLD-RATE 750W 12V Power Supply
  • Windows 8.1 64Bit Operating System DVD English International
  • Standard Build Service (5-7 Working Days)
  • TP Link TL-WN881ND 300Mbps Wireless N PCI Express Adapter
  • Corsair Air Series SP120 LED Red 120mm Case Fan
https://linustechtips.com/topic/482974-fallout-4-pc-issues-general-issues/
AMD doesn't have a "game-ready" driver yet for Fallout 4, give it a bit of time. There'll be pressure.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
Tried turning vsync on?
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
thanks man yeah patches and drivers will help in time. but any idea why i have the same issues on other games ?
Not sure, it might actually be the CPU, Fallout's on of the relatively few games to properly take advantage of all of the FXs cores. and it's been known to be a bit of a bottleneck for a card like the 390 when a game only uses 4 or fewer cores.
Or maybe Vsync, make sure that's off as well.
good suggestion guys i will try turning v sync off. i dunno if its because i am not using a ssd at all would buying one help get a more consistant frame rate. it fell like when it happens its when the gaming is trying to load in assests. just a thought ?
sometimes, but uncommon.
ok once i finish work i will have a play with v sync is there a way of making fallout 4 locked to 30 fps just so i can play it without having as much of a drop in fps
Yeah if you lock your screen at 30hz. Otherwise, might be your CPU
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
My AMD PC is under min spec's and I get 60FPS at Ultra with only motion blur turned off and the occassional dip in FPS.
Phenom II x4 805
6GB DDR @ 1066MHz
Using a program like HWinfo, are you able to locate your PC's hardware bottleneck? If not it maybe just they way the game is optimised. (Or lack of)
It's not that. I can run the game on one of my 290's at 1440p high settings FXAA at around 60-70fps average.
It's not the storage speed either. I'm running it off a 7200rpm HDD just fine.
Something else is going on here. @cpratt447 - first thing to try is turning off vsync. The game has vsync turned on by default and the only way to disable it is to edit an ini file. Go to the following directory:  C:/...users/[name]/documents/my games/fallout4  and open up the "fallout4prefs.ini" using notepad. Under the [Display] heading (should be the first one) look for the following line: iPresentInterval=1 and change it to iPresentInterval=0. Make sure you SAVE it before you close it. Now, run the game again and let us know what your frame rates are. ;)
Also, if you can, run MSI afterburner to monitor your GPU usage, clocks and temps while gaming. And if you can, also monitor CPU usage, clocks, and temps. If you have a second monitor, this should be easy. If not, you'll have to alt-tab out a few times to see how things are running.
My Systems:
Main - Work + Gaming:
Woodland Raven: Ryzen 2700X // AMD Wraith RGB // Asus Prime X570-P // G.Skill 2x 8GB 3600MHz DDR4 // Radeon RX Vega 56 // Crucial P1 NVMe 1TB M.2 SSD // Deepcool DQ650-M // chassis build in progress // Windows 10 // Thrustmaster TMX + G27 pedals & shifter
F@H Rig:
FX-8350 // Deepcool Neptwin // MSI 970 Gaming // AData 2x 4GB 1600 DDR3 // 2x Gigabyte RX-570 4G's // Samsung 840 120GB SSD // Cooler Master V650 // Windows 10
HTPC:
SNES PC (HTPC): i3-4150 @3.5 // Gigabyte GA-H87N-Wifi // G.Skill 2x 4GB DDR3 1600 // Asus Dual GTX 1050Ti 4GB OC // AData SP600 128GB SSD // Pico 160XT PSU // Custom SNES Enclosure // 55" LG LED 1080p TV  // Logitech wireless touchpad-keyboard // Windows 10 // Build Log
Laptops:
MY DAILY: Lenovo ThinkPad T410 // 14" 1440x900 // i5-540M 2.5GHz Dual-Core HT // Intel HD iGPU + Quadro NVS 3100M 512MB dGPU // 2x4GB DDR3L 1066 // Mushkin Triactor 480GB SSD // Windows 10
WIFE'S: Dell Latitude E5450 // 14" 1366x768 // i5-5300U 2.3GHz Dual-Core HT // Intel HD5500 // 2x4GB RAM DDR3L 1600 // 500GB 7200 HDD // Linux Mint 19.3 Cinnamon
EXPERIMENTAL: Pinebook // 11.6" 1080p // Manjaro KDE (ARM)
NAS:
Home NAS: Pentium G4400 @3.3 // Gigabyte GA-Z170-HD3 // 2x 4GB DDR4 2400 // Intel HD Graphics // Kingston A400 120GB SSD // 3x Seagate Barracuda 2TB 7200 HDDs in RAID-Z // Cooler Master Silent Pro M 1000w PSU // Antec Performance Plus 1080AMG // FreeNAS OS
ok mate i will try that abit later on thanks :) i have had the issue with the pc since i got it tbh even had issue with fallout new vegas doing the same thing however not regularly. i upgraded to windows ten would that make a difference at all.
Windows 10 has been giving a number of people issues in PC gaming. Just make sure you have the latest drivers installed (15.11 I think is the latest), even though AMD doesn't have their official fallout 4 drivers out yet, keeping up to date with drivers can still help with overall system stability.
My Systems:
F@H Rig:
HTPC:
Laptops:
NAS:
  • 2 weeks later...
hey guys thanks for the advice on this but i am still not running right even on normal setting i get drops from 60 to 40 even 30 fps at times. i can even see the textures trying to load as i am working around turning vsync did help but not massively. i even tried ruuning on low where the game is kind of stable but will drop to around 50 fps at time when sprinting or going to a built up area like a settlement. any other ideas guys
