Hey, planning my first build which will be a HTPC build, the budget is around 1500 USD for which I need help deciding the components and any special components as it a HTPC .right now I have fixed
1. Case- corsair carbide air 540 .
2. Motherboard- Asus Maximus VIII ranger or Asus Maximus VIII hero??
3. Processor- Any Intel skylake processor, however i am confused between a locked or unlocked processor?? since I feel uncomfortable with overclocking(voiding warranty,higher tdp,and risk)
4. Please suggest wether special components like a sound card or tv tuner are needed???
5. GPU- GTX 970 or R9 390X or wait for PASCAL gpu's ??
Any help from the community will be highly appreciated, Thanking in advance.
https://linustechtips.com/topic/482395-my-first-build-htpc/
imho for an HTPC you should really keep an eye on power consumption, an i3/i5 with a 750/950 would be the better approach.
i think he may be a bit confused. i think he may mean mitx
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/482395-my-first-build-htpc/#findComment-6471748
I think you're sort of misunderstanding the purpose of an HTPC, you're better off using that money to being a NAS/plex media server
What do you want to use it for?
https://linustechtips.com/topic/482395-my-first-build-htpc/#findComment-6473652
