While putting together parts for a  PC I was wondering which architecture I should use. There seem to be arguments in favor of both and I'm having trouble deciding. Haswell is a tried and true platform with a large amount of options and generally cheaper motherboard and RAM prices, while going with Skylake would have the advantages of the newer architecture along with the ability to upgrade to newer processors without changing the motherboard, later on down the line. Which should I choose?
As a side note, this PC will mostly see gaming or Office Suite work. I will not be doing rendering or editing of any kind, so I'm probably sticking to at most an i5.
https://linustechtips.com/topic/482104-skylake-or-haswell/
Haswell is cheaper and Skylake is slightly better.  It's up to you.
Neither has a significant advantage from what I know.
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/482104-skylake-or-haswell/#findComment-6467920
@pcman365 I dont agree as there are still people rocking 2500K and 2600K which is already 4+ years now.  Its really depends on how you will use your CPU.  From a gaming perspective, haswell is more than capable and the gain you get from Skylake doesn't give more values for the additional cost for DDR4.
GAMINGCLICHE: Core i5 6500 - Gigabyte H170N-WiFi - Deepcool Gabriel - 16GB HyperX Fury - Asus Strix GTX 1070 OC - NZXT Manta
ORANGEJULIUS-720p: Core i3-3230 - Noctua 9UB-SE2 - Gigabyte B75N-itx - 8gb GSkill Ares - GTX 650Ti - Bitfenix Prodigy (RETIRED)
https://linustechtips.com/topic/482104-skylake-or-haswell/#findComment-6468904
Get a new build, go with Skylake. more PCIe lanes to go around for multiple devices that you might want to add down the road.
https://linustechtips.com/topic/482104-skylake-or-haswell/#findComment-6469362
Digital Foundery has proven that Skylake is much better for gaming.
If anyone asks you never saw me.
https://linustechtips.com/topic/482104-skylake-or-haswell/#findComment-6469414
If you can get the gpu you want while going Skylake, then Skylake is the way to go for the faster memory and more pcie lanes. If you can't get the gpu you want in a Skylake build but can in a similar Haswell one, then go Haswell, the gpu is more important. The gpu+monitor is most important, the cpu second, and nothing else matters nearly as much.
https://linustechtips.com/topic/482104-skylake-or-haswell/#findComment-6469600
but if you go for haswell you wont have as much upgradebillity in the future
https://linustechtips.com/topic/482104-skylake-or-haswell/#findComment-6474829
Better = Skylake vs Cheaper = Haswell
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/482104-skylake-or-haswell/#findComment-6475014
