Help Need for GPU
Go to solution Solved by Guest,
-snip-
Any R9 380 but preferably from either MSI or Sapphire, whichever is the cheapest.
Why?
R9 380>GTX 960
MSI and Sapphire have really good aftermarket coolers.
Hi guys Just need some help regarding these GPU. Can you please help me out in picking one I will appreciate the help .
1. XFX R9 380 4GB 256-Bit GDDR5 R9-380P-4255 Graphics Card
2. EVGA 04G-P4-3966-KR SuperSC ACX 2.0+ GeForce GTX 960 4GB 128-Bit GDDR5 Graphics Card
3. Gigabyte GTX 960 G1 Gaming 4 GB GDDR5 Graphics Card GV-N960G1 GAMING-4GD
4. SAPPHIRE NITRO R9 380 4GB 256-Bit GDDR5 100384NT4GOCL Graphics Card
5. MSI R9 380 GAMING 4G 256-Bit GDDR5 Graphics Card
Thanks
https://linustechtips.com/topic/481694-help-need-for-gpu/
Can you please tell me what makes EVGA stand out compare to others ?
Nothing. It's worse than the 380' s and at a higher cost.
Buy the Sapphire R9-380.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/481694-help-need-for-gpu/#findComment-6461562
Do you have any suggestion
The Sapphire. It's the best 380 you can buy.
https://linustechtips.com/topic/481694-help-need-for-gpu/#findComment-6461571
XFX vs Sapphire ?
Sapphire. The XFX, as @HydraGaming said, is louder.
https://linustechtips.com/topic/481694-help-need-for-gpu/#findComment-6461586
I would go for EVGA.
Fanboy much?
https://linustechtips.com/topic/481694-help-need-for-gpu/#findComment-6461592
EVGA got better components and best customer services.
Butthurt much? If you are here to bitch and not to voice your opinion then shut the hell up.
But the performance is still worse. I don't care what you say; a 960 is still worse than a 380.
Honestly, you seem the most butthurt and salty.  :P
https://linustechtips.com/topic/481694-help-need-for-gpu/#findComment-6471218
