HP Build quality
Solved by Virtual01,
Hmm... I have never actually read the temperature of laptops. I found a review in Thai language (which I cant read... so by the power of Google Translate) which say something like the idle temp is about 30 on the surface, 40-45 on the middle of the keyboard) and while playing games like GTA it never gone pass 79 degree Celsius. Is it high or not?
79 is pretty hot for a laptop, and out of some peoples comfort range on desktops. It's a laptop, and that number will only go up over time.
