Hi,i asked someone if they could help me for a Pc build in the 800-1000 dollar range.These are the parts he/she game me.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($172.89 @ OutletPC)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($71.89 @ OutletPC)
Storage: Mushkin Chronos 120GB 2.5" Solid State Drive  ($53.45 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($44.89 @ OutletPC)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($357.99 @ Amazon)
Case: Fractal Design Define S w/Window ATX Mid Tower Case  ($88.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($103.86 @ Mac Mall)
Total: $962.44
Generated by PCPartPicker 2015-11-08 18:57 EST-0500
This gets you quad core, gaming performance for the ages, a PSU with the possiblity of Crossfire, and an ssd :3
Could you tell me if there are better choices? (I'm new to pc building and components.)   THANKS!
https://linustechtips.com/topic/481520-first-pc-build/
few minore changes... you dont need the cooler or a 750 w psu unless you plan on going crossfire/sli
i would go this route myself for ~$1000
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ Micro Center)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: ASRock Z97 Anniversary ATX LGA1150 Motherboard  ($84.98 @ OutletPC)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($79.99 @ SuperBiiz)
Video Card: XFX Radeon R9 390 8GB Double Dissipation Video Card  ($313.98 @ Newegg)
Case: Corsair 300R ATX Mid Tower Case  ($66.99 @ Amazon)
Total: $964.29
Generated by PCPartPicker 2015-11-08 19:07 EST-0500
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/481520-first-pc-build/#findComment-6459171
PCPartPicker part list / Price breakdown by merchant
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.59 @ Amazon)
Memory: Crucial Ballistix Sport 8GB (1 x 8GB) DDR3-1600 Memory  ($39.89 @ OutletPC)
Total: $962.44
Looks pretty good but you could save a bit of cash and get a bit more performance with the following:
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1600 Memory ($42.69 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($86.95 @ Amazon)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($79.99 @ NCIX US)
Total: $946.28
Generated by PCPartPicker 2015-11-08 19:08 EST-0500
You don't need that cooler, the stock one is fine for that chip. Dual-channel RAM gives better performance and 250gb SSD's are the new 120gb. Also changed the powersupply but change it back if you are going to upgrade/crossfire in the future.
Good luck!
https://linustechtips.com/topic/481520-first-pc-build/#findComment-6459190
It's absolutely perfect... you can just dump that 212 EVO though, can't OC so the stock cooler will be fine. I have the same motherboard and an i5-4590 :) I love it
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/481520-first-pc-build/#findComment-6459192
Better temps arnt a bad thing though. :3
@TechGod
the hype 212 evo is loud. If he's OK with a loud cooler then it should be fine.
https://linustechtips.com/topic/481520-first-pc-build/#findComment-6459193
Total: $946.28
Good luck!
I support this :3
Moist
https://linustechtips.com/topic/481520-first-pc-build/#findComment-6459209
Good luck!
 You could go with a single 8gb stick it does not really mater much because you are not using the onboard graphics. And if you sell it the ram later a 8gb stick is worth more then 2x4gb
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/481520-first-pc-build/#findComment-6459457
