Monitor suggestions?
Solved by ThinkWithPortals,
I've just added it as a placeholder, i'm just open for suggestions against it, Do you think the LG widescreen will be much smaller, as that's what's putting me off it, but it does have freesync and is £70 cheaper.
To be honest, the one that's there pretty much looks like the best you could get in that price range. If we're thing about the same LG widescreen (29 inches?) than it's the same height as a 24 inch normal monitor, so that's for you to judge whether you can deal with the reduced height. Bear in mind that the LG widescreen will be easier to run games on than a 1440p monitor (2560x1080 vs 2560x1440)
