Mine uses around 500W on heavy load, so 850W should be good.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/479825-how-much-power-do-i-need/#findComment-6436475
CPU - i7-6700k 4.00ghz
CPU cooler - Corsair 100i gtx
MoBo - Asus Maximus VIII hero
Graphics cards - 2 MSI GeForce GTX 980ti in SLI
Monitor - Acer XB270HU bprz
Im also looking to overclock the cpu in the furture.
thanks.
850W would be the sweet spot for that. EVGA's GS/G2 would do you perfectly!
https://linustechtips.com/topic/479825-how-much-power-do-i-need/#findComment-6436705
750W of good quality would do but i would shop for 850W for more headroom.
Great monitor BTW :)
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/479825-how-much-power-do-i-need/#findComment-6437189
