Ok, so I got an asus 750ti and plugged it in, installed all of the drivers and it seemed to work fine. My display is being outputed as normal. But my performance is exactly the same in games if not worse than it was before I installed it. Why is that. I can't figure it out
https://linustechtips.com/topic/478257-750ti-problem/
Cause it's a low end card?
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/478257-750ti-problem/#findComment-6407704
what are the rest of your system specs?
the 750Ti isn;t that powerfull, tough you should be seeing a significant performance increase as opposed to integrated graphics.
maybe in-game you have it set to use the iGPU?
https://linustechtips.com/topic/478257-750ti-problem/#findComment-6407714
What are you comparing it to?
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/478257-750ti-problem/#findComment-6407717
Did you plug the display port into the GPU or the motherboard?
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/478257-750ti-problem/#findComment-6407724
Im comparing it to an amd radeon graphics apu and yes I plugged the hdmi into the graphics card. And yes, thank you for letting me know my card isn't cery expensive. Still though. It should be better than what I've seen
can you tell us your settings and performance figures
https://linustechtips.com/topic/478257-750ti-problem/#findComment-6407775
When I got my 750Ti, it nearly maxed out most 1080p games. Something is wrong, did you install Nvidia Geforce drivers? It could also be a bottleneck somewhere else, although I doubt it.
I am conducting some polls regarding your opinion of large technology companies. I would appreciate your response.
Microsoft Apple Valve Google Facebook Oculus HTC AMD Intel Nvidia
I'm using this data to judge this site's biases so people can post in a more objective way.
https://linustechtips.com/topic/478257-750ti-problem/#findComment-6407783
I'm sure that somethings wrong I just don't know what
Make sure to use a driver thats known to work good with the 750Ti,I for instance use the 353.30,as Ive encounetered many problems with the latest drives,I suggest going as back as installing one from like June.If that doesnt do it,update to the latest one and try again.If that doesnt work,check if your system is running on ANY power saving feutures,like the Power Plan in windows is set on Power Saving and not High Performance,or in the Nvidia Control Panel the mode is Adaptive and not Prefer Maximum Performance.If that doesnt resolve the issue,check if your PCI-E power conector is connected right,and also check if your PSU has enough wattage for the 750Ti.If that doesnt do anything,try other games too!It may be just DayZ!Let me know if that aint the issue and also what CPU are you running at?
Shark Rampage V: AMD FX-4350 @ 4.5GHz(1.404 Volts) / Hyper 212 Evo / Gigabyte 750Ti (1405MHz Core,3200MHz Memory @ stock voltage) / Kington HyperX Fury 8 Gigs 1866MHz Dual channel / ASUS M5A97 R2.0 / WD Caviar Blue 1TB 7200 RPM / 850Evo 250GB / XFX TS 550w 80+ Bronze Sharkoon VG4-W
https://linustechtips.com/topic/478257-750ti-problem/#findComment-6408425
