I need a psu for this build
 - Modular
 - Compatible with cable mod red and black cables
 - Under 100 USD would be nice
http://pcpartpicker.com/p/vdFWhM
Thanks guys, Payton
P.S. I like the build how it is
Before i see your build i have to tell you this. Don't cheap out on a PSU. You want to spend around $130-160 on a PSU usually for a single GPU
Looks like a Corsair RM850i ($160 USD) or Corsair RM850 ($130) would be just fine.
If you want the difference then ask.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6401913
Alright you like the build it is. Can you not spend the extra money on the 4690k since you are getting a Z97 board?
Also PSU, 650w EVGA GS OR G2
Any XFX or SeaSonic
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6401918
Before i see your build i have to tell you this. Don't cheap out on a PSU. You want to spend around $130-160 on a PSU.
WHAT?
No. LOL you can get a $40 EVGA B2 750w when it is on sale and let me tell you, that is a rock solid PSU. Same goes for XFX, just recently they had a 550w P1 for $26. Rock solid PSU.
@STRMfrmXMN Take a look at this, apparently you need $130-$160 for a good PSU.
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6401926
Geez, i need to keep this under 900
https://pcpartpicker.com/part/evga-power-supply-220gs0650v1
I was thinking that
Change the Z97 to H97. You'll  be fine and save a few bucks. By the way I've heard people say nasty things about EVGA's non G2 power supplies.
Save up. DOn't buy a cheap PSU! Unless you want to unleash satan in your house and have all hell break loose.
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6401931
I was thinking that
You do not need to spend $130-$160 on a PSU. A 850w EVGA GS is $120 and is probably the best price-per dollar PSU. This one is golden, the EVGA GS is a OEM SeaSonic PSU
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6401932
Any XFX or SeaSonic
The Z97 board is cheaper than the h97 i wanted to get. Also its so i can get a 4690k later on when i have more cash
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6401935
Stop spitting false information. The GS is just as good and in some cases BETTER then the EVGA G2. G2 is made by SuperFlower, GS is made by SeaSonic.
The EVGA B2, G2, GS, PS. T2, and P2 are very good power supplys.
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6401941
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6401942
Personally if you get the i5-4460, the upgrade to the 4690k would not be worth it.
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6401949
OMG I hate hypocrites. You either have money and are looking for a way to not spend much or you need to to find your computer Build priorities..
OMFG.
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6401951
OMG I hate hypocrites. You either have money and are looking for a way to not spend much or you need to realize this will save you money in the long term.
OMFG.
Im getting the Z97 for 2 reasons
 - I can get a 4690k later on when i have more money
 - Its cheaper than the H97 board right now, so i can save money. (so i dont have to buy a new mobo and cpu to overclock)
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6401966
No need to buy a 4690K later!
Your build is fine without it.
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6401980
OMFG.
Please stop.
He wants that board, he can get it. $99 for Z97 board is not bad and it matches is color scheme. Why will you not answer the post I quoted on you?
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6401985
-snip-
Do you know anything about a power supply? Tell me, TELL ME ONE THING wrong about the EVGA GS? Because you can't, it is a fantastic power supply, especially for the money. It is a SeaSonic rebrand, which may I mention have some of the most reliable PSUs. So tell me, how is it bad? Would you rather reccodmend a Corsair RM series because it is more expensive? Or do you not know the Evga GS series is better than the Corsair RM series?
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6402011
My build is fine now, but i can make it better later on with a 4690k and a new closed loop. I can overclock it and get more performance. Whats wrong with that?
Spending $250 US more for 2-5% better performance is absolutely crazy.
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6402016
Keep on ignoring me. Why?
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6402036
WHAT?
Lol, I'll have you know that the EVGA G2 can be afforded for $100. Great PSU but you can go cheaper. The EVGA GS (a G-series Seasonic rebrand) is less money (also what I use in my rig). Need cheaper? Antec HCG, EVGA B2, XFX anything... The list goes on.
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6402442
http://pcpartpicker.com/part/evga-power-supply-220gs0650v1
I was thinking about the one above
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6402890
That will work!
https://linustechtips.com/topic/477819-alittle-more-help/#findComment-6403891
