Hello, I recently bought a Lenovo Thinkpad x220. I am looking to replace the mechanical hard drive with a ssd. I am looking for something in the 240-250 GB range. Out of these drives which one would you recommend and WHY? Also, if you have an better suggestions feel free to let me know of them. Keep in mind though I am only looking for 240-250 GB and am looking to stay in the $70-80 price range at most. Also, it has to be 7mm. For what its worth, right now I am leaning towards the Crucial one.
Thanks!
http://www.amazon.com/Samsung-2-5-Inch-Internal-MZ-75E250B-AM/dp/B00OAJ412U/ref=sr_1_2?ie=UTF8&qid=1446424306&sr=8-2&keywords=7mm+ssd
http://www.amazon.com/Kingston-Digital-SSDNow-SV300S37A-120G/dp/B00A1ZTZOG/ref=sr_1_3?ie=UTF8&qid=1446424306&sr=8-3&keywords=7mm+ssd
http://www.amazon.com/Crucial-BX100-250GB-Internal-Solid/dp/B00RQA6TEI/ref=zg_bs_1292116011_3
http://www.amazon.com/SanDisk-Ultra-2-5-Inch-Height-SDSSDHII-480G-G25/dp/B00M8ABFX6/ref=sr_1_5?ie=UTF8&qid=1446424306&sr=8-5&keywords=7mm+ssd
https://linustechtips.com/topic/477555-ssd-decision-help/
Samsung 850 EVO is the best SSD here.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/477555-ssd-decision-help/#findComment-6398337
I cba to open the links so I'm assuming you picked a Crucial BX100 250GB SSD, a Samsung 850 EVO, an SSDNow and something else.
I'd go for the crucial one since it's the middle ground between speed and price. SSDNow is crap and the EVO in this case would be a little expensive. Give the adata SP550 SSD a look though, it appears to be quite good for the price.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/477555-ssd-decision-help/#findComment-6398353
Between Crucial and Samsung, which one would you recommend?
The crucial. The Samsung drive isn't really that much faster (for sustained operations, the Phison S10 controller is king, and neither has one), and they haven't been pitted against each other for reliability yet (that takes a year and a half at least) so... imo the crucial for the price.
There are others out there you could look at. OCZ(Toshiba) and Adata SSDs are really good for the price.
https://linustechtips.com/topic/477555-ssd-decision-help/#findComment-6398375
the 850 evo
faster and more durable with the 3d nand technology they use
its more expensive, but not by a lot and IMO worth it
https://linustechtips.com/topic/477555-ssd-decision-help/#findComment-6398402
This. And as I said before, Adata SP550 250GB is like $70.
USEFUL LINKS:
https://linustechtips.com/topic/477555-ssd-decision-help/#findComment-6398405
Why is that?
Thanks
Why is that? 5 years warranty compared to 3 of those other SSDs - that should convince you to get the Samsung over the rest. It's also faster, featuring a 3D NAND technology. You can't go wrong with that SSD.
https://linustechtips.com/topic/477555-ssd-decision-help/#findComment-6398607
