problem with phone
Go to solution Solved by GammaProX,
i fixed it i had to go to runnig apps go to google search and then some keyboard options showed up and i unchecked google voice keyboard and it seems to be fixed
so my phone a prism 2. i know its old and bad and i hate the phe but its all i have. but lately its unusable because something pops up saying unfortunately, Google Search has stopped. and i press okay and it pops up again and it wont stop. i got into the running apps and i found it. i clicked on it and i can't force close it or anything. i cant text or anything because it just pops up over and over and resting my phone doesn't help either. anyone have any suggestions? sometimes it wont pop up right away so it gives me time to try to do something to fix it.
and i didnt install google search its just preinstalled i dont think you can uninstall it.
https://linustechtips.com/topic/476552-problem-with-phone/
do a hard reset, there should be a phone repair tool
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/476552-problem-with-phone/#findComment-6385978
