Hello, I am going to be getting a powerline adapter soon because my WiFi is horrible. I have 3 questions though.
1.) Will I get better speeds when I am on powerline vs WiFi? (Right now I am getting 600 KB/S) :(
2.) Is their a difference between these two and which one is better? Also, if you have any recommendations in the $40 price range feel free to suggest them.
http://www.amazon.com/TRENDnet-Powerline-Nano-Adapter-TPL-406E2K/dp/B008F537KC/ref=zg_bs_1194444_16
http://www.amazon.com/TP-LINK-TL-PA4010KIT-Powerline-Adapter-Starter/dp/B00AWRUICG/ref=zg_bs_1194444_1
3.) I want to be able to do wake on LAN but since I am on WiFi right now I can't. With poweline since its Ethernet cable will I be able to do wake on LAN
Thanks so much.
https://linustechtips.com/topic/476275-powerline-help/
1) If you're currently far away from your wireless source and your promised internet speeds are better than 600kbs then yes. Else, no.
2) Go for the TP-Link one.
3) Not sure what you mean with wake on LAN.
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/476275-powerline-help/#findComment-6382650
Thank you and just curious, why do you say the TP-Link one over the Trendnet one?
Also, I mean like turning the computer on remotely from like Teamviewer.
https://linustechtips.com/topic/476275-powerline-help/#findComment-6382663
I have a TP link one myself and I'm really happy about it, way better than the cheap brand I had before that. (Also, a tip, try to plug the powerline adapters right into a plug and not a box with multiple plugs.)
https://linustechtips.com/topic/476275-powerline-help/#findComment-6382684
Thanks for the info!
should mention..powerline adapters only work well on modern copper wiring
if you like in a place with old bad wiring..it might be slow or not work at all
only way to really tell is to actually test it
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/476275-powerline-help/#findComment-6383222
