I'm thinking about getting a usb hub for for a few devices and for my mechanical keyboard and mouse. I mostly want one because so I can hide my cables better, so my questions are, does a USB hub affect performance in a mechanical keyboard or mouse? And can it affect something like a wifi adapter?
https://linustechtips.com/topic/476015-does-a-usb-hub-affect-performance/
I am not sure how true is it
But i do believe if you use the hub for keyboard and mouse
it still ok
but I am not sure how will the wifi adapter will affect the keyboard and mouse
USB means Universal Serial Bus
so data is transferred using a single data line
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
No the USB hub is not reliable source to chain your USB devices.
The single connection has a limit in which it connects to the computer, and if you maximize the use of all ports, it will bottleneck entire thing.
Has this happened to you?
You can get powered USB hubs and they can remove the power limitation which is often a problem with hard drives and other power hungry devices. Its rare to hit reserved bandwidth limitations on USB 2 and especially on USB 3 hubs because most devices don't use that much but it can occasionally be an issue. You usually these days hit power limits much faster because 500ma from the USB port isn't enough for 1 hard drive let alone a load of devices.
I personally run a USB 3 powered hub with 7 ports that has my mouse/keyboard/phone/trackir/headphone amp etc etc in it. Most of the reserved bandwidth budget is the mouse, but the power draw of an AMP + phone exceeds what the port on the computer can output, so powered vastly improves the recharge rate of both.
