He probs needs it for compatability
well, then get a 6300, because an 8530 won't improve gaming performance in the slightest.
Recovering Apple addict
ASUS Zephyrus G14 2022
CPU: AMD Ryzen 9 6900HS GPU: AMD r680M / RX 6700S RAM: 16GB DDR5
https://linustechtips.com/topic/475488-will-my-pc-bottleneck/#findComment-6371734
Dude it's more like is your PC going to blow up because of the VRMs and Mosfet overheating on the mATX AM3+ board.
FX 8xxx CPUs aren't designed for mATX boards, you need a 970 or higher.
FX 6xxx is the max you would go in a mATX config.
So fx-6300?
https://linustechtips.com/topic/475488-will-my-pc-bottleneck/#findComment-6371751
just get this instead, it's better in every way:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($163.99 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard ($64.80 @ SuperBiiz)
Memory: Crucial Ballistix Sport XT 8GB (2 x 4GB) DDR3-1600 Memory ($34.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.66 @ SuperBiiz)
Video Card: MSI Radeon R9 280 3GB TWIN FROZR Video Card
Case: Antec Nine Hundred ATX Mid Tower Case ($79.20 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply ($29.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.20 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home OEM (64-bit)
Total: $436.83
Generated by PCPartPicker 2015-10-28 22:43 EDT-0400
as you can see it's even cheaper and you can use the intel heatsink on this one...perfect!
If you already own the AMD motherboard then i would recommend either to sell it and order this i5 and H97 board...or just get the FX-8320 and save some money...overclock it to match the FX-8350 speed...it's easy, but this motherboard isnt meant for FX-83XX...
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/475488-will-my-pc-bottleneck/#findComment-6371760
Ummm form factor has nothing to do with it, just the chipset and power delivery to the cpu
LTT's Fastest 9800gt
LTT Forum Beginners Guide
https://linustechtips.com/topic/475488-will-my-pc-bottleneck/#findComment-6371842
that 3 FPS is probably due to the fact that the 8350 is clocked higher, not the extra cores.
https://linustechtips.com/topic/475488-will-my-pc-bottleneck/#findComment-6371915
Do you understand how mosfet and VRMs work on AM3+ boards...
Form factor is a problem on AM3+ boards when the mATX board has shitty VRMs, mosfets, and poor power delivery that wouldn't handle the CPU.
Try to find a AM3+ mATX board that can handle a FX 8 core properly without it catching on fire....
https://linustechtips.com/topic/475488-will-my-pc-bottleneck/#findComment-6371928
I want to upgrade the CPU since I don't game as much but when I do play its medium-high intensity games (GTAV,TF2,etc). So I was hoping that the processor upgrade would help.
Your just better off selling the board, since FX is a dead platform..
Honesty unless you need heavy rendering, content creation uses at a cheap price, want ECC ram, there's no point in FX.
https://linustechtips.com/topic/475488-will-my-pc-bottleneck/#findComment-6371937
I just said that the FORM FACTOR ITSELF does not effect the quality of a board, but rather the components the manufacturer decides to use. I was not talking about any board or platform in particular, but just the form factor.
https://linustechtips.com/topic/475488-will-my-pc-bottleneck/#findComment-6376648
both of you are right, there is no good quality mATX AM3+ motherboard and there probably never will be...but sure there could have been, ASUS or gigabyte could have made super awesome 8 or 10 phase digital 990FX mATX boards...but they didn't because this would be a very niche market cause who would like to run a CPU that can pull around 280W from the wall when fully overclocked on such a motherboard...you don't want that in a small form factor machine...a 250W GPU yeah ok that make sense if performance if up there...but for an underperforming outdated CPU?! nobody would want that i guess.
https://linustechtips.com/topic/475488-will-my-pc-bottleneck/#findComment-6376743
