hey all so im whant to make a pc that will be able to record games at atlest 30fps (like minecraft tf2 gmod stuff like that)  but i dont have mutch in the way of money my my budgit is £200 hear is a list of parts that i allredy have from a old pc
case
evga geforce 210 (1gb) dont know if this one is good or not for gaming
and
500 watt psu
and i need the parts from amazon.co.uk if posable
also play fallout 4 at atlest 20fps not recording (can tollarate that)
https://linustechtips.com/topic/475193-pc-build-parts-help/
Please save up more money. You are looking at for £200 every little thing cheaped out and it will be good for no more then office use. £500 is the aboslute lowest anyone should spend on a PC. Just find a used console at this point.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/475193-pc-build-parts-help/#findComment-6367787
the games listed are not that resource intensive
minecraft tf2 gmod
https://linustechtips.com/topic/475193-pc-build-parts-help/#findComment-6376257
here is a motherboard, processor, ram , ssd and mouse/keyboard for about 142
http://imgur.com/kARsfoF
what else do you need? If you already have a mouse and keyboard that's about 16 off right there.
edit- I doubt this will run fallout 4 tho. Minecraft and source games sure. but for less than 200 this will work for what you want
https://linustechtips.com/topic/475193-pc-build-parts-help/#findComment-6376447
1) Minecraft needs at minimum 6GBs of ram. I have tried to run it on 4 and since you have to dedicate atleast 3, it is not fun. Minecraft is runs off shitty Java, you need at minimum a Pentium G3258.
2) GMOD needs some form of GPU. A APU simply will not cut it. Atleast at playable framerates.
https://linustechtips.com/topic/475193-pc-build-parts-help/#findComment-6379109
1- minecraft does not need 6 gb not even close. My moms dell with 4gb and onboard intel pentium graphics and it runs just fine. gmod and source games run just fine on apu's. Maybe not at ultra but they run. Where are you getting this info??
https://linustechtips.com/topic/475193-pc-build-parts-help/#findComment-6404729
Personal experience.
Played minecraft with a little old pentium and 4GBs of ram for 2-3 years. Played it on my Grandmas laptop with a Centrino and 4GBs of Ram. Not fun. I could only dedicate 2GB otherwise the PC and laptop would run really slow. This would cause frequent crashes and modded was not a thing past like 10mods.
https://linustechtips.com/topic/475193-pc-build-parts-help/#findComment-6408283
