Upgrading my Old PC : need Help
Go to solution Solved by AverageHardware,
Can you suggest a good i3 CPU? or should I need to go for an i5?
i3 4170 or the NEW i3 6100.
I use an i3 4170 and I can play Battlefield 4 on High at 1080p. I have a GTX 750.
If you want even more power and can afford it, the i5 is definitely worth it.
i5 6600 or i5 4690k
Hi,
I am planning to upgrade my old PC into a mid to high end gaming PC.
Current Build :
AMD Phenom X3 8450 2.1GHz
ASUS M2N68-AM PLUS MOBO
2 x 2GB DDR2 RAM
320 GB 5200rpm HDD
NVIDIA GeForce 8400GS 512MB
My question is that if I need to play GTA V, Assassins Creed Syndicate, FIFA 16 at  40-60fps at medium to high settings and I want to only change the CPU and GPU which CPU and GPU combo would be the best?
If I change the GPU to GTX 750Ti or GTX 960 without changing the CPU, will these game bottleneck?
Thank You
https://linustechtips.com/topic/475121-upgrading-my-old-pc-need-help/
750 Ti is fine, 960 ain't fine.
A 960 will definitely bottleneck the CPU. A 750Ti would also be right on the edge. If you want my opinion, save and start everything fresh with a budget build using an i3 + 750/750ti/some amd card
i7 4790k | GTX 970 | 16GB
That's all you need to know. It's a beast.
750Ti is better than 960 you say?
the 960 is bad in the sense theres a better GPU (the r9 380) for the same price
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
i5 6600 or i5 4690k
I use an i3 4170 and I can play Battlefield 4 on High at 1080p I have a GTX 750.
i5 6600 or i5 4690k
Ok. Thanks a lot for your advice. I will build a new one then.
Thank you guys for the quick response.  :)
If you need help with a build, post in the "New builds and planning" section, and lots of people will help you out. Just specify your budget, and what you plan to use the PC for.
