Witcher 3 help
Go to solution Solved by don_svetlio,
you can go anywhere and get killed everywhere. Enjoy :)
Hi guys,
I just finally started the Witcher 3 :D.
I was wondering about the openness and speed of the game. There are some sidequests which advise a certain level (I'm only 2 now) and I was wondering if parts of the world are inaccesible once you have come to a certain point in the main storyline like in the witcher 2.
So if I start talking to people about Yennefer now and follow the story line, will I still be able to do the sidequests in the Ransacked Village and Woesong Bridge etc later on?
Thanks
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/475083-witcher-3-help/
https://linustechtips.com/topic/475083-witcher-3-help/#findComment-6366025
Hi guys,
Thanks
You will have access to most things until the end. There are a few side-quests that go away because of events in the main quest messing them up, but very few. There are guides that tell you which those are so you can make sure and do them.
There's another thing, though. When I played it a few months ago, you didn't get XP for quests that were recommended for 4 levels or more below what you are. So that would be something to consider if you're going for an XP maximization run. There was talk that they might patch that out, but I'm not sure what happened. My next playthrough is still a few months away xD
https://linustechtips.com/topic/475083-witcher-3-help/#findComment-6366062
There is a point in the game where if you haven't completed certain side quests, they will become unavailable. However, the game makes it a point to pause and tell you this (and give you the option to turn back). This happens around a certain story event, so I won't spoil it by elaborating.
https://linustechtips.com/topic/475083-witcher-3-help/#findComment-6366084
No, some things aren't accesible at the very start. Now I can't remember the name, but those islands which you reach at rank 30-40, those for example aren't accesible at the start. Now I played the game a long time ago so I may not remember it correctly or some patch changed that
Longboarders/ skaters message me!
https://linustechtips.com/topic/475083-witcher-3-help/#findComment-6366091
Thanks y'all.
Now I can enjoy my game with peace of mind ^.^
My System:
https://linustechtips.com/topic/475083-witcher-3-help/#findComment-6366104
At some Point you dont care about older sidequests anymore . You will be too powerfull, you wont need the rewards anymore and you will get almost no exp. Just move forward. There are so many things to do, that you will lose interest in the Game bevore finish them all.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/475083-witcher-3-help/#findComment-6366175
