CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/474847-evga-970-question-about-airflow/
The fans push air from below onto your GPU and then the majority of the heat goes inside of your case.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
The fans push air from below onto your GPU and then the heat goes inside of your case.
ok thanks... just making sure the fan i have on the bottom of my case as an intake isnt fighting with the gpu
Wait, i thought cool air going into the fans and hot air exhaust through the back of the GPU.
thats for blower styles
That's with a closed design. This is open. Some heat will certainly go out the back, but open air designs push heat wherever it can go, including inside the case.
so would you say a  200r with this configuration would be good?
1 fan as intake in the front, 1 fan as intake on the bottom, 1 fan as exhaust on the top, and my h80i in push pull as intake on the back, psu is bottom facing
It'll be fine, a rear intake is a bit of an unconventional choice tho. I haven't had any throttling issues with my ssc, the cooler is quite good
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
figured it wouild be better to cool the rad with outside air then warm air from inside the case thats why i went with intake
it was the only place i was able to mount the rad
If you pull Air from the rad into the case, the rest of your components would be warmer by a few degrees. At least your CPU is cooler doe, I have a 280mm pull from the front and it seems to be doing okay.
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
i use my drive cages so the only place i can put the rad is on the rear of the case
I have my rad as my only exhaust and even with my 970 oc'd it doesn't affect my cpu temps by more than a couple degrees. Using a rear intake introduces turbulence which can create dead zones. But if you aren't running into any issues, then no reason to change it
My rig:
Probably fine, but I would actually recommend adding a second fan as intake in the front, and using the h80i as exhaust. Trying to maintain a mostly direct airflow through the case, with slightly positive air pressure, is in my experience always the best way to go. Also, make sure all your intakes are filtered, or you risk dust building up a lot more easily.
