Upgrading my Old rig Need Help
Go to solution Solved by Arwanell,
ok now only remaining is GPU
so i cant afford 390 or 390x in india
so which options do i have
then go with 970, it will last you at least for a year, then sell it and buy another one
in the end of 2016 much can change
Hello all
hope you all are doing great
i have a problem
My rig is
AMD phenom IIx4 940
msi 790Fx motherboard
4 gb gskill ram (1333)
saphire 5850 GPU
550 Tagan PSU
nzxt phantom case
i am planning to upgrade it i need some suggestions
i am from india and budget is almost 30k-40kINR ($460-$620USD)
i am using this pc for Gaming and photo &video editing
planning to use 2 monitors 1080P@60hz (gaming only on one screen)
no peripherals
i am upgrading because my motherborad is damaged (reason unknown even service center couldn't tell me) i repaired the mobo but it failed aging so am planning to replace the mobo only but i thought its time to move on
i am so confused to intel or amd
shoud wait for 380x or go nvidia
i am planning to run this pc more 3yrs at most
and i want to play all games @ ultra settings 1080P smoothly
any help is appreciated
https://linustechtips.com/topic/473505-upgrading-my-old-rig-need-help/
Hello all
You'll want an i5 4460 or an 8320/e with actually a 970, because if I remember right, last time I checked in india at least, the 390 was priced way higher than the 970 for some reason.
Now if somehow you can get a 380x I'd do that, but I think the card is out just yet, if the 390 is the same price do that, otherwise get a 380 if it's signifigantly cheaper
You'll also probably want a new power supply as well
thanks for reply but i want unlocked version in intel i will overclocking in future (not much Lil bit)
thats true 390 is way higher priced in india
may be i will crossfire or sli
970 had some issues i heard thats why i am hesitating to get one
Unless you're getting a 144hz display the unlocked i5 won't really matter
so any other suggetions?
Not really, DDR4 won't be worth it, but if skylake doesn't cost much more than haswell where you are might as well go skylake
