Bloody A6 - How to change Lights?
PampaZiya
So I got a new one. My friend has it will all red lights. Mine is multi-color, it's cool, but I really want it red too. He forgot how he changed it, I downloaded the software (Bloody 5). But I can't find where to change the colors? There's a buttons tab. It has "Profiles" in it with all the lighting currently on my mouse but I can't seem to know how to change them.
  • 7 months later...
I have the same problem, just got the mouse but I have no idead how I could change it. Have you solved this mistery yet?
  • 2 years later...
Hi ,, I also have bloody A60 and I've found the solution for your question :)
1. I used bloody 6 driver.
2. Go to Light Brightness Mode.
3. Choose Neon Glare System
4. Wait until the colors you want to set up appear.
5. When the colors you want appeared change to breathing mode.
6. The colors will stay and do not change
nb* you have to do this every time you restart your pc or laptop cause the setting cannot be saved by the systems.
*edited : you cannot set up the colors as yous want, you only choose what system show on your mouse in glare mode. The bloody 6 system also said " V/VM/A/N Series do not support light changing function ".
Edited by KaisarError
  • 1 year later...
On 10/25/2015 at 7:25 PM, PampaZiya said:
Hi there,
I have only M1, M2, and M3. is there a way to add more profiles? i could not find a way to add. I have V7.
Thanks.
  • 10 months later...
I found the solution just press the color wheel then pick the color you want and pick the shortcut / hotkey by clicking the keyboard icon
then press your selected hotkeys then click exit instead of ok then you got you color you wanted (Works on latest bloody soft ware bloody7)
