CPU: Intel Core i5-2500K 3.3GHz Quad-Core Processor ($214.99 @ SuperBiiz)
Motherboard: Biostar H61MGV3 Micro ATX LGA1155 Motherboard ($37.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1866 Memory ($41.99 @ Amazon)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive ($39.99 @ Micro Center)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($44.89 @ OutletPC)
Video Card: Sapphire Radeon R9 270X 4GB Dual-X Video Card ($168.99 @ SuperBiiz)
Case: Xion XON-310_BK MicroATX Mid Tower Case ($23.98 @ Newegg)
Power Supply: Cooler Master Elite V2 550W ATX Power Supply ($24.99 @ Micro Center)
Total: $597.81
Generated by PCPartPicker 2015-10-25 03:34 EDT-0400
Tell me if I'm wrong
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/473142-low-budget-pc-build/#findComment-6342001
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($42.89 @ OutletPC)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked Video Card  ($99.99 @ Newegg)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  ($24.99 @ NCIX US)
Total: $338.13
Generated by PCPartPicker 2015-10-25 03:35 EDT-0400
The Pentium G3258 might have a few stutters on very CPU intensive AAA titles, but at least it has an upgrade path, as opposed to the Athlon X4 860k AMD Quad-core. Simply put in another stick of the same memory when it's time to upgrade, and maybe swap the video card to a 970 strix. CPU can be pushed all the way to an i7 or e3 1150 Xeon.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/473142-low-budget-pc-build/#findComment-6342004
Well you need to include a budget because we cant really help you.... because someone definition of budget is different to another person.
Magical Pineapples
https://linustechtips.com/topic/473142-low-budget-pc-build/#findComment-6342027
A pretty decent budget build, I'd say
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($113.99 @ NCIX US)
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard  ($66.98 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($42.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.33 @ OutletPC)
Video Card: EVGA GeForce GTX 950 2GB Superclocked Video Card  ($154.99 @ SuperBiiz)
Case: Cooler Master Elite 130 Mini ITX Tower Case  ($43.99 @ SuperBiiz)
Power Supply: Silverstone 450W 80+ Bronze Certified SFX Power Supply  ($59.99 @ SuperBiiz)
Total: $535.16
Generated by PCPartPicker 2015-10-25 04:01 EDT-0400
And regarding what the other person above me said about getting the pentium, it is far better to get a dual core that has hyperthreading. Especially since the Pentium one stutters with modern AAA games.
Went with an ITX build since it looked the more cost effective route
https://linustechtips.com/topic/473142-low-budget-pc-build/#findComment-6342063
Second. Also, you could probably run GTA V without any lag or problems on a potato at its lowest settings at 900p. This alone tells us nothing about your system. Furthermore, you could spend $13258971235919234 (exaggeration) on a PC that can play GTA V just fine but just represents really poor value for your money, or blows out your budget anyway.
Help us to help you.
https://linustechtips.com/topic/473142-low-budget-pc-build/#findComment-6342073
