Hello ,
I got budget of 3200$ i.e 2,10,000 inr in my country :
Shop Links :
www.primeabgb.com
http://theitwares.com/
www.theitdepot.com
Above 3 normally have lowest prices :
www.amazon.in - Mostly sells at high prices .
SAMPLE BUILD : http://prntscr.com/8v1i41   ( u can modify it )
Side note : If you suggesting EVGA brand it is not available & i don't plan to import it .
My Confirmed Parts since i do video editing , gaming & work on this .
CPU: i7 5820k
Monitor : BENQ XL2430T 24INCH  ( if any better or equal price let me know )
RAM : 32 GB DD4  Speed : ??
GPU : ??
SSD : ??
HDD : ??
CASE : Looking for MID or Full tower which should fit everything & Dust fillter + Great air flow , which help me a lot since it's very dusty here .
MOBO : ?? X99
PSU : Looking for reliable PSU should run 5+ year without failure
CPU Cooler : ??
Side notes : Yes i love overclocking , i am running 4.5 GHZ i5 3570k .
I plan to upgrade GPU in future and go 4k sli with above rig .
I plan to use 2 Monitor from my existing setup for work .
Suggesting with reviews and benchmarks will bonus making your points more valid .
PS : Those who give me best advice they can pick any games worth 30 Euros , i will select a winner .
I plan to buy before month end , so suggest before 27-28th oct.
Regards
https://linustechtips.com/topic/473108-3200-budget-pc-help-required/
What country? There's international PCP versions, but not a lot.
Shop Links :
www.primeabgb.com
3,200 $ is 2,10,000 inr Country : India .
I am not shipping from USA since that will void warranty .
Cant you do price conversions?
Yes i can price conversions if tell me your suggested parts
GPU = 980Ti K|NGP|N / Lightning (TBA)
SSD = 850 PRO 500GB ( or 1TB ) + Intel 750 400GB PCIe SSD ( or 1.2TB+ ) TBA 950 M.2 SSD
HDD = 1TB Caviar Black
Case NZXT = Phantom 820 ( 4 5.25 Bay so you can have space for Custom Loop )
Motherboard = X99-PRO ( OC-Socket, OC Power Phase, lots of OC Feature )
PSU = EVGA G2 850 - 1000W
CPU Cooler = H110i GTX
why not just buy from PPC ?
i'll try to make the Shop Link
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
GPU = 980Ti evga hybrid
HDD = 6TB Caviar Black
Case Lian Li pc-08 ( if availbale )
Motherboard = Asus X99-deluxe
consider doing something like this, gorgeous but ofc depends whether the case is available in your country or not.
recreate this will be nice also.
CPU:  i7 4770k @ overclocked to 4.4ghz             GPU: Intel HD4600        SSD: Kingston V300 120GB (OS)                   Cooler:  Corsair H100i GTX
Case: Phanteks Enthoo Evolve (Black)                RAM: 2x4gb Corsair Dominator Platinium 2133mhz  HDD: 1TB Seagate                                            Mouse: Logitech G502
OS:     Windows 10                                                      PSU: Corsair RM850i 80+ Gold                                          Motherboard:  AsusZ97 Pro Gamer              Keyboard: Vortex Pok3r 3
Went through that whole site to make a build,
5820K - 29,500
http://theitwares.com/computer-hardware/processors/intel-processors/intel-core-i7-5820k-haswell-e-6-core-3-3ghz-lga-2011-v3-140w-desktop-processor.html
Gigabyte GA-X99-Gaming 5 - 29,000
http://theitwares.com/computer-hardware/motherboards/intel-motherboards/gigabyte-ga-x99-gaming-5-lga-2011-v3-intel-x99-sata-6gb-s-usb-3-0-extended-atx-intel-motherboard.html
G.Skill Ripjaws 4 - 11,825 (Not many ram options on that site)
http://theitwares.com/computer-hardware/memory-ram/desktop-memory/g-skill-ripjaws-4-series-f4-2400c15d-16grr-16gb-ddr4-2400-desktop-memory.html
Corsair Force LS series - 4,250 (not a lot of ssd options there)
http://theitwares.com/computer-hardware/hard-drives-ssd/ssd-hard-drives/corsair-force-ls-series-2-5-120gb-sata-iii-mlc-internal-solid-state-drive-ssd.html
2tb WD black hdd - 9,700
http://theitwares.com/computer-hardware/hard-drives-ssd/internal-hard-drives/western-digital-2tb-black-wd2003fzex-wd-2-tb-internal-desktop-hard-drive.html
Corsair Graphite 780T - 14,950
http://theitwares.com/computer-hardware/cabinets/corsair-graphite-series-780t-white-atx-full-tower-full-tower-pc-case.html
Corsair AXi 860w platinum fully modular - 17,000
http://theitwares.com/computer-hardware/power-supplies/corsair-axi-series-ax860i-860w-digital-atx12v80-plus-certified-full-power-supply.html
Gigabyte gtx 980 - 49,750 (best that site had I believe)
http://theitwares.com/computer-hardware/graphic-cards/nvidia/gigabyte-gv-n980g1-gaming-4gd-gtx-980-4gb-256-bit-gddr5-pci-express-3-0-hdcp-ready-sli-support-g-sync-support-video-card.html
Corsair H100i dual rad- 8,500
http://theitwares.com/computer-hardware/cooling-devices/water-cooling/corsair-hydro-series-h100i-gtx-240mm-water-liquid-cpu-cooler.html
Total 174,475
RAM = G.Skill Ripjaws 4 DDR4 F4-2133C15Q-32GRK 32GB RAM
GPU = ASUS STRIX-GTX980TI-DC3OC-6GD5 Graphic Card
SSD = Intel 750 Series 400GB PCIe SSD SSDPE2MW400G4X1
Case = NZXT PHANTOM 820 FULL TOWER CABINET
Motherboard = ASUS X99-PRO MOTHERBOARD
PSU = Corsair CX Series RM750 750W Power Supply
CPU Cooler = CORSAIR HYDRO SERIES H80I GT HIGH PERFORMANCE WATER/LIQUID CPU COOLER.
+ 10K INR
www.primeabgb.com
probably change the PCIe to normal SATA SSD to lower the Cost, or get X99-A to lower the cost, or get MSI 980Ti Gaming
Thank you for stealing my SSD
Thank you suggestion i have added a sample build :  http://prntscr.com/8v1i41
Thank you  for suggestion i have added sample build : http://prntscr.com/8v1i41
+ 10K INR
www.primeabgb.com
i actually steal the whole thing and edited actually. sorry about that haha my bad i should've ask for permission first sorry again =P
if you don't need a beast gpu maybe you can go with a 390 since it performs better than 970 with a lower price tag and twice the vram.
But this is just a suggestion since there are other things nvidia offers that amd don't such a game stream to your nvidia shield and also the software. I personally like nvidia experience even i am using 390x nw. ( i used to use a 970 btw)
But if you don't need those and just want raw performance and slightly better future compatibility, go with a 390 namely from sapphire, powercolour and also msi.
-snoop dogg-
3.2K USD and you use 970 ? you kidding me ?
dont get the HXi its bad, get the RM
errr.... that is the part list he quote me on with a 970. So yeah, i am just respecting his choice btw.
and rmi or rmx is way better.
Just a suggestion , 3,200 USD is 2,10,000 INR , yes parts are expensive here ! :( ... So if you can figure things out to add a better GPU in there by adjusting other parts will be nice
CPU = 5820K
Monitor = XL2430T
GPU = MSI GTX 980Ti GAMING 6G LE Graphic Card
SSD = Seagate Desktop Hybrid 2TB SSD ST2000DX001
Motherboard = ASUS X99-A MOTHERBOARD
201.000 INR :D
Same GPU + Overclock Motherboard + SSD Performance HDD
Thank you for all the Help but i have decided to go with Following help :
CPU = i7 5820k
Ram = DDR4 2400 MHZ - Ripjaw 4
GPU = Asus Strix 970 ( Reason i am not making a 980ti build is because Pascal is very near & i feel it's going major ugprade , so will sell 970 and get TI then )
HDD = WDD black 2tb
SSD = 850 EVO ( I wanted 950 EVO but currently it will take 2-3 months to arrive here will add them later )
Mobo = Asus Deluxe 3.1 x99  ( Reason i am going with this it has almost all features of Asus Rampage V + I needed Dual Lan to have 100% Uptime Internet )
CPU Cooler = Nzxt Kragen X61 ( Noctus D15 is only worth comparing , but it's very heavy and ugly on the mobo )
Case = Nzxt 820 Black
PSU = Antech HCP 1000W Plantinum or Crosair AX 860 ( if available )
Thanks
