Mouse Issues with DeathAdder 2013
So my Dad and I just recently finished building my new desk and its great, really smooth, etc.
The only problem is that my Razer DeathAdder 2013 is having problems now, like I think its because the desk is so smooth.
The mouse always has interuptions, like when I move to the left sometimes it will go up and around, sometimes it will go completely spastic.
Does anyone know what's wrong?
Thanks in advance, Sabron.
Sennheiser HD600 Logitech G304 White Anne Pro 2 LG27UL500
Ryzen 5 3600 + MSI B450i Gaming Plus AC in Fractal Design Nano S
https://linustechtips.com/topic/47279-mouse-issues-with-deathadder-2013/
do you have a mousepad?
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
It's because you're not using a mouse pad.
Mice are designed to track on a mouse pad and not a desk.
Get a steelseries QCK+ and you'll be good to go.
It's what I use with my deathadder 2013 and it's brilliant.
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
I wasn't using a mouse pad on my previous desk, it didn't have this problem.
Building new desk > Likely made of wood > Laminated with varnish & smooth.
Optical mice can't track on shiny/transparent/glossy surfaces. Just grab a mousepad sheesh
with a high end mouse you should have bought a mouse mat in the first place to really take advantage of it
| 3570k @ 4.4.ghz | Hyper 212 evo | 8GB (2x4GB) 1600mhz Corsair Vengeance | Gigabyte Z77X UD3H | Corsair CX750M | Corsair 300R | OCZ 240GB SSD | Seagate 1TB 7200rpm HDD | Asus DCUII 7950 @1150mhz core 1600mhz mem
| BenQ XL2411T | Corsair Vengeance K60 | Logitech G700 | steelseries Qck+ | Fiio E10 | Zalman clip on mic | HD 598 | ATH-M50 |
Meh, its 11:30PM, I'll just have to buy one tomorrow then.
Pathetic Effort by Razer.
How the hell is this a pathetic effort by Razer? For your info IIRC the Deathadder 2013 is fitted with one of the best optical sensors in the market currently available.
Optical mice can't track on glossy/transparent surfaces as i stated previously. If you can afford a $60 dollar mouse, having no mousepad & bashing a company for your own fail & oversight is distasteful indeed!
its not razers problem that some mice have difficulty on shiny surfaces its not their problem you didn't invest in a mouse mat
exactly if I tried using my g700 on the desk I have which is glossy black it doesn't move really at all I'm not calling up logitech having a fit because I didn't buy a mouse mat
I really like the mouse, and how it feels but did they really need to go optical?
you bought the mouse why didn't you just find a laser one and what is wrong with optical it is better than laser at lower dpi and it doesn't have mouse acceleration issues
Sadly, you probably don't realise that if they went with a laser sensor, your mouse won't feel the same.
And for your info, optical sensors track better than laser & have no inherent mouse acceleration associated with how laser mice work. Laser sensors are for companies to market their >9000 'omgwtf imba dpi'
Edit: Just grab a Steelseries QCK, excellent cloth mousepad & cheap.
Well thanks for the info then, I'll have to a razer mouse pad tomorrow.
get a steelseries mousepad they're great and some are huge if you need it
U just went full retard, never go full retard.
more like lack of common sense to use a mousepad.
I never had to use in my entire life, but okay.
Lol, I felt like saying that cause I was pissed.
Anyways, what mousepad would you guys recommend? really smooth, fast.
Artisan Shiden Kai. Current fastest soft pad. Made in Japan.
So you blame razer for it. Logic. They never forced you to buy their mice.
Yeah so, if you had read what I said, you'd understand why.
CPU: i5 4690K  CPU Cooler: Corsair H100   Motherboard: Gigabyte Z97X UD3H   Memory: G.Skill (2 x 4GB) DDR3-1866   Storage: Samsung 830 Series 128GB 2.5" SSD/Seagate Barracuda 1TB 3.5" 7200RPM   GPU: EVGA GeForce GTX 660 Ti SC 2GB   Case: Cooler Master CM 690 II (Black) ATX Mid Tower   PSU: CORSAIR Enthusiast Series TX650M 650W 80 PLUS BRONZE Certified   Optical Drive: MSI DH-24AAS-17 R DVD/CD Writer   Operating System: Windows 10 Pro (64 bit)
