I guys I buy an gtx 770 PNY
and i seems to have very loud sort of sound coming out when i do the Benchmark and the graphic card  have some white line poping in
And when i play metro last light to i kind a  see those line anyone can help ?
Rig; HAF XB===ASUS GTX TITAN===ASUS CROSSHAIR V FORMULA Z===16GB CORSAIR VENGEANCE 1866MHZ===FX VISHERA 8350 OC===CORSAIR HX 750 WATTS ===ANTEC SILENT FAN X 4===2x HYPER X 128GB SSD===CORSAIR SLEEVED CABLE BLACK/RED===SOUND BLASTER ZXR
https://linustechtips.com/topic/47190-gtx-770-help/
With 3D Marks at load I hit 69c And whats RMA am noob Sorry
https://linustechtips.com/topic/47190-gtx-770-help/#findComment-625237
RMA = Return merchandise authorization
It's basically returning it to who you bought it from for a replacement, refund, or repair.
https://linustechtips.com/topic/47190-gtx-770-help/#findComment-625248
oh sorry cause am french XD
https://linustechtips.com/topic/47190-gtx-770-help/#findComment-625256
The noise you're hearing is most likely coil whine.
https://linustechtips.com/topic/47190-gtx-770-help/#findComment-625276
You will probably have to RMA the card and what you are hearing is coil whine, what you are seeing is called artifacts. It could also be heat check what temps you have with GPU Boost 2.0 you should be around 80C at load.
Even so, because of the way GPU Boost 2.0 works, the card on paper should continue underclocking to keep itself from going over that mark. (if it has to underclock itself)
https://linustechtips.com/topic/47190-gtx-770-help/#findComment-625293
Sounds like your probably getting coil whine like the others pointed out, might wanna rma (warranty) that card if its artifacting though, My 770 has been flawless even under full load and oc'd, highest ive hit on air is 76 degrees, highest gaming temps have been 63 degrees
https://linustechtips.com/topic/47190-gtx-770-help/#findComment-625294
What PSU do you have? Sometimes a certain PSU and GPU don't mix well for some reason and cause coil whine. (but it's most likely the GPU since the GPU is the one making the noise)
Workstation: 3930k @ 4.3GHz under an H100 - 4x8GB ram - infiniband HCA  - xonar essence stx - gtx 680 - sabretooth x79 - corsair C70 Server: i7 3770k (don't ask) - lsi-9260-4i used as an HBA - 6x3TB WD red (raidz2) - crucia m4's (60gb (ZIL, L2ARC), 120gb (OS)) - 4X8GB ram - infiniband HCA - define mini  Goodies: Røde podcaster w/ boom & shock mount - 3x1080p ips panels (NEC monitors for life) - k90 - g9x - sp2500's - HD598's - kvm switch
ZFS tutorial
https://linustechtips.com/topic/47190-gtx-770-help/#findComment-625365
