Hello,
So, my PSU was making a bad noise a long time ago, and now i decided to check it out and clean some dust.
I found out that two of my capacitors blown, but the computer seems fine, and works fine.
I tried to see online what psu it is but i cant find anything.
It's a UNYKA 600W.
I'm afraid that the psu can Blow the rest of my System.
I was planing to buy a Corsair CX-600W (80+), do you recomend(?).
System specs:
UNYKA 600w
Asus P8H77 -M LE
Intel i5 3470
Asus strix gtx 960 4gb
HD green 500gb (yeah green)
8gb ddr3 1600mhz corsair
btw i had a pci wireless and stopped working, dont know the reason.
post-228489-0-49145900-1445441022_thumb.
https://linustechtips.com/topic/471062-psus-capacitator-blown-help/
The Corsair CX600W isn't one of the few good CX PSU, so avoid it. And looking at the ratings on that PSU (specifically the 5V rail), its design dates back to the days of the Pentium III, AKA back to around 1998-2000, so I'm not surprised its had issues.
Edit: If I had a soldering iron and high quality capacitors, I'd almost kill for a PSU with a 5V rail like that.
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
So i was browsing on my usual stores is this one good?
http://www.pcdiga.com/2/18323/Fonte-Seasonic-S12II-430W-SS-430GB?marca=6294 ?
TY
Yup.
it's probably the same psu i picked, lel
Yeah i know but are u sure 430W it's enough? I think it is, even now this gtx 900's series with this arquitecture.
Thanks for the help guys,
Much love
The 960 is a power sipper, and even with the i5, it'll be more than good enough.
TY
You're fine - 960 draws 180W on average.
Much love
Yes... I even ran it on a 250W for a test :/
As long as you don't buy Nox, Tacens, Unyka, L-Link.... basically any <50 € PSU that claims 600W or more that looks sketchy AF you're fine.
Also you've at the same price the S12II series PSU, similar but with more cables if you need them: http://xtremmedia.com/Seasonic_S12II_430W_Bronze.html
This is a signature.
Yeah like 1life 30€ 1000W :DD
That was the same that i posted http://www.pcdiga.com/2/18323/Fonte-Seasonic-S12II-430W-SS-430GB?marca=6294
Oh didn't notice.
I like how pins is said... "pinos"...
Looks funny to me because that means pines in Spanish :P
get on my level - GameDemon 750W for 10 eu :P
