hi guys,
            Planning a upcoming build which will be aperture science themed. looking for a white case (atx) with a nice big window and space for at least 2 240 rads. So far the only thing i have seen are the phantoms(530) but they look a bit plasticy, are there any other options out there? i wouldn't mind doing a bit of modding if needed.
thanks in advance :)
Cpu:4670k- at stock.... for now Gpu:r9-280x crossfire Cooler:KrakenX40 MB:mpower SP Ram:8gb hyperX beast
https://linustechtips.com/topic/47009-need-a-white-case/
The NZXT Switch 810 should suit your needs.
https://linustechtips.com/topic/47009-need-a-white-case/#findComment-622449
Intel i5 3570K - ASRock Extreme4 - Corsair Vengeance 8Gb RAM - ASUS GTX 660 Ti - Samsung 840 250Gb SSD (OS-Games) - WD 750Gb HDD (Storage) - Corsair TX650W PSU - Corsair 300R
https://linustechtips.com/topic/47009-need-a-white-case/#findComment-622457
The R4. It can fit a top 240 and a front 240 when you move the drive cage back if you mod you can fit a 280 in the front.
yes but it'll be so squished inside, i want my pc to large and graceful. Shame because its such a nice case :(
https://linustechtips.com/topic/47009-need-a-white-case/#findComment-622471
hello beautiful, now to find one on this tiny spit of land :(
*scratch that, drive cage yuck!
https://linustechtips.com/topic/47009-need-a-white-case/#findComment-622479
According to the review I read, Switch 810 has a completely plastic outer body. (Except for side panels)
The Corsair Vengeance C70 is also an option.
https://linustechtips.com/topic/47009-need-a-white-case/#findComment-622487
suppose, i could just paint bits of it. then there is the window, any idea of where i can get acrylic sheets in the uk?
https://linustechtips.com/topic/47009-need-a-white-case/#findComment-622504
http://www.theplasticpeople.co.uk/cut-to-size-plastic-c-140.html
https://linustechtips.com/topic/47009-need-a-white-case/#findComment-622511
I would try the Storm Stryker from CM. It's pretty big and can house up to 9 5.25" drive bays.
https://linustechtips.com/topic/47009-need-a-white-case/#findComment-622529
dont need any hard drives and honestly i think  it looks like it was designed by a nine year old child. "more fins, more lights, more better". :( thanks anyway tho
https://linustechtips.com/topic/47009-need-a-white-case/#findComment-622546
too bad that the phanteks enthoo primo doesn't come in white that would be right up your alley. I would say look at the nzxt H630.
https://linustechtips.com/topic/47009-need-a-white-case/#findComment-622572
love the front/ top of that h630 but the lack of a window is a killer. how hard would it be to mod a window in?
https://linustechtips.com/topic/47009-need-a-white-case/#findComment-622595
I would imagine as hard as any other case.
https://linustechtips.com/topic/47009-need-a-white-case/#findComment-622613
