Ram is ram. Its fine as long as its the same gen like ddr2 and ddr3. DDR3 goes in a ddr3 mobo and ddr2 goes in a ddr2 mobo.
Main Gaming PC - i9 10850k @ 5GHz - EVGA XC Ultra 2080ti with Heatkiller 4 - Asrock Z490 Taichi - Corsair H115i - 32GB GSkill Ripjaws V 3600 CL16 OC'd to 3733 - HX850i - Samsung NVME 256GB SSD - Samsung 3.2TB PCIe 8x Enterprise NVMe - Toshiba 3TB 7200RPM HD - Lian Li Air
Proxmox Server - i7 8700k @ 4.5Ghz - 32GB EVGA 3000 CL15 OC'd to 3200 - Asus Strix Z370-E Gaming - Oracle F80 800GB Enterprise SSD, LSI SAS running 3 4TB and 2 6TB (Both Raid Z0), Samsung 840Pro 120GB - Phanteks Enthoo Pro
Super Server - i9 7980Xe @ 4.5GHz - 64GB 3200MHz Cl16 - Asrock X299 Professional - Nvidia Telsa K20 -Sandisk 512GB Enterprise SATA SSD, 128GB Seagate SATA SSD, 1.5TB WD Green (Over 9 years of power on time) - Phanteks Enthoo Pro 2
Laptop - 2019 Macbook Pro 16" - i7 - 16GB - 512GB - 5500M 8GB - Thermal Pads and Graphite Tape modded
Smart Phones - iPhone X - 64GB, AT&T, iOS 13.3 iPhone 6 : 16gb, AT&T, iOS 12 iPhone 4 : 16gb, AT&T Go Phone, iOS 7.1.1 Jailbroken. iPhone 3G : 8gb, AT&T Go Phone, iOS 4.2.1 Jailbroken.
https://linustechtips.com/topic/46986-will-these-two-go-together/#findComment-622103
I used to think that RAM is RAM and that as long as it's the supported speed it would work, I was wrong however.
I had the privilege to work with the Corsair Vengeance RAM  and the Asus 990FX Sabertooth R2.0, the RAM turned out to be unsupported and this caused a lot of serious stability issues, including corrupted source files, blue screens and system hangs.
I would highly recommend reading the memory support list of the motherboard via the motherboard manufacturer's website.
You can find the memory support list for the GA-A55M-DS2
here : http://www.gigabyte.com/products/product-page.aspx?pid=3998#memory%20support%20list
and for the GA-G41M here :
http://www.gigabyte.com/products/product-page.aspx?pid=3505#memory%20support%20list
If the memory modules are not supported you can run them, however you will need to go into the BIOS and enter all the primary timings yourself.
https://linustechtips.com/topic/46986-will-these-two-go-together/#findComment-622197
I remember when someone faked themselves as PNY and sold 800mhz ddr2 sticks quoted as ddr3.
Listen if you care.
https://linustechtips.com/topic/46986-will-these-two-go-together/#findComment-622305
