I need help
Go to solution Solved by i_build_nanosuits,
CPU AMD FX 8310
Memory DDR3 16GB
GPU MSI GTX 980
MOBO M52_M32BC(Socket 942)
PSU EVGA 600W
 that is about all i got but if you need more info to determine tell me and ill see if i can find out some more
i would get this and re-use your memory:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($229.99 @ NCIX US)
Motherboard: ASRock Z97 PRO3 ATX LGA1150 Motherboard ($80.98 @ Newegg)
Total: $310.97
Generated by PCPartPicker 2015-10-18 00:14 EDT-0400
This will have better performance than the i5-6400 out of the box, and it's unlocked so in the future you can do some overclocking and get even more performance out of it if needed, but even at stock it wont limit the performance of your GTX980 in games.
CPU AMD FX 8310
Memory DDR3 16GB
GPU MSI GTX 980
PSU EVGA 600W
Total: $310.97
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/469050-i-need-help/page/2/#findComment-6291645
Total: $310.97
honestly this sounds better but you did make sure my compontents will fit such as the mobo fitting in the tower and all the other compatibility etc.
https://linustechtips.com/topic/469050-i-need-help/page/2/#findComment-6291683
if you want to make sure the motherboard will fit in the case just pick a microATX motherboard, those will certainly fit...i can't find detailed spec for your machine, knowing the size of your current board would be nice but i assume microATX will fit:
http://pcpartpicker.com/part/asrock-motherboard-z97mpro4
https://linustechtips.com/topic/469050-i-need-help/page/2/#findComment-6291717
looks like it will fit to me also is it possibly for my board to not come off my machine and 1 last thing will i need to just place my memory in and boom it there or will i need to move it over somehow
https://linustechtips.com/topic/469050-i-need-help/page/2/#findComment-6291832
ok forget that question but one more thing are you sure that that the cpu will not bottleneck because the mhz are lower than my current or are the mhz irrelevant
You cant compare processors with just megahertz. For example my 3770 at 4ghz will outperform an amd fx 9590 which runs at 5ghz.
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/469050-i-need-help/page/2/#findComment-6293977
Optical Drive ASUS SH-244DB
Storage TOSHIBA DT01ACA200
OS 8.1 64 Bit
if you want an overclocking cpu..then you probably the the i5 6600k
I don't really think its necessary tho
skylake is newer and will be upgradeable atleast once...maybe twice...haswell is basically over
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/469050-i-need-help/page/2/#findComment-6295146
they will not release anything that will be a worthy upgrade to the 6600K on the socket 1151...they never do.
Skylake is only a few % faster than haswell and it's a lot more expensive and this user already own 16GB of DDR3 RAM he could re-use so skylake in this case is absolutely NOT worth it.
https://linustechtips.com/topic/469050-i-need-help/page/2/#findComment-6295169
thanks for your help guys i will be going with the parts that nansuit gave me now the hard part will be convincing my dad that the mhz dont matter because i ask him and he just says that its a quad core with 3.4mhz and should be fast enough but you guys cant help me with that but im grateful of the help
https://linustechtips.com/topic/469050-i-need-help/page/2/#findComment-6297373
what games/game types are you playing the most and at what resolution?
https://linustechtips.com/topic/469050-i-need-help/page/2/#findComment-6300551
payday 2 1920x1080 bf4 1920x1080 Killing Floor 2 1920x1080 everything maxed on all games i have a few other games that i play often but arent worth mentioning so i figured my hardware would be overkill and thats not the case but hopefully the new cpu and mobo will resolve this
https://linustechtips.com/topic/469050-i-need-help/page/2/#findComment-6305304
forgot to mention i play on 144hz
https://linustechtips.com/topic/469050-i-need-help/page/2/#findComment-6305306
yeah...BF4 should run well on your current hardware though right? maybe not 100FPS+ but at least 60FPS consistently?
you will get better performance with a better CPU though, the GTX980 is a very strong GPU and you do need a good CPU to be able to get the most out of it in games.
AMD FX have okay multi-threaded performance, but the per core performance (single-threaded) is fairly low by today's standard and this hurt the CPU performance in games a lot at times.
https://linustechtips.com/topic/469050-i-need-help/page/2/#findComment-6305607
Thanks for the help but when i use a different board and new cpu will just moving my memory be fine and its there or will i have to do something els im not very famialar with these type of things
https://linustechtips.com/topic/469050-i-need-help/page/2/#findComment-6306204
just remove the memory form the old board and install on the new one and it should work fine.
https://linustechtips.com/topic/469050-i-need-help/page/2/#findComment-6307851
