I need help
Go to solution Solved by i_build_nanosuits,
CPU AMD FX 8310
Memory DDR3 16GB
GPU MSI GTX 980
MOBO M52_M32BC(Socket 942)
PSU EVGA 600W
 that is about all i got but if you need more info to determine tell me and ill see if i can find out some more
i would get this and re-use your memory:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($229.99 @ NCIX US)
Motherboard: ASRock Z97 PRO3 ATX LGA1150 Motherboard ($80.98 @ Newegg)
Total: $310.97
Generated by PCPartPicker 2015-10-18 00:14 EDT-0400
This will have better performance than the i5-6400 out of the box, and it's unlocked so in the future you can do some overclocking and get even more performance out of it if needed, but even at stock it wont limit the performance of your GTX980 in games.
alright so im trying to upgrade my cpu on a prebuilt pc and i dont understand how can i tell if my mobo is compatable if the mobo name is m52bc which happens to be the name of my prebuilt so should i just buy a cpu and if it doesnt work send it back i am hoping to get a intel i5 or higher but i dont want to have to mess around with compatability give me some advice please
https://linustechtips.com/topic/469050-i-need-help/
What is the cpu you have right now? Knowing that will let us know which chipset the motherboard is and we can go from there
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/469050-i-need-help/#findComment-6291070
Download a program like speccy, it'll tell you what motherboard & cpu you have. From there you can find out what socket it is and find out what you need to upgrade it.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/469050-i-need-help/#findComment-6291072
Model M52BC_M32BC(socket 942)
https://linustechtips.com/topic/469050-i-need-help/#findComment-6291193
Well you have an top AM3+ CPU so there really is no upgrading. Sadly the FX 8--- CPU's just aren't great.
https://linustechtips.com/topic/469050-i-need-help/#findComment-6291226
so no uprgrading but say i were to get a compatible mobo with a cpu i want would that work i have a pretty big case i think its considered a tower
Yeah, what's your budget? I'm sure I could recommend something pretty good.
https://linustechtips.com/topic/469050-i-need-help/#findComment-6291276
well i dont know exactly becasue the way i will be getting the money would be from selling my old xbox 360 console and games plus my xbox one controllers and games so lets say like $450 but i have a msi gtx 980 that is clearly being bottlenceck so give me what will cpu and mobo are compatible but will not bottleneck my gpu
https://linustechtips.com/topic/469050-i-need-help/#findComment-6291288
Do you game only? or do you do video & photo editing too?
https://linustechtips.com/topic/469050-i-need-help/#findComment-6291307
if i need to go over that it is ok but that is where i would like it to be but i am willing to pay more so i can finally get good performance
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($183.89 @ OutletPC)
Motherboard: Asus H170-PRO ATX LGA1151 Motherboard  ($105.34 @ Amazon)
Total: $343.22
Generated by PCPartPicker 2015-10-17 23:34 EDT-0400
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/469050-i-need-help/#findComment-6291390
im
Total: $343.22
this probably sounds dumb but ddr4 is ram? right
https://linustechtips.com/topic/469050-i-need-help/#findComment-6291396
ok forget that question but one more thing are you sure that that the cpu will not bottleneck because the mhz are lower than my current or are the mhz irrelevant
nope..it will be fine
any i5 can keep up with any single gpu card
https://linustechtips.com/topic/469050-i-need-help/#findComment-6291457
