Hi,
I'm going to be building in the SG13B soon and was wondering what the best PSU would be. I was looking at the Seasonic S12II but I feel like it might be a bit too big. Are there smaller/better ones? 500w+ please.
My parts list (if you care): http://pcpartpicker.com/p/GRBCYJ
https://linustechtips.com/topic/468910-power-supply-for-sg13b/
Hi,
That Seasonic is pretty small but non-modular. Will the EVGA GS 550W fit in your budget? It happens to be modular and really small.
https://linustechtips.com/topic/468910-power-supply-for-sg13b/#findComment-6289228
You could look at SFX/SFX-L units, Hardware Canucks used one in their Fractal Core 500 video. Seemed to make the whole process easier and tidier.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/468910-power-supply-for-sg13b/#findComment-6289233
  • "The EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply length of 150mm exceeds Silverstone Sugo SG13B Mini ITX Tower Case maximum of 140mm."
https://linustechtips.com/topic/468910-power-supply-for-sg13b/#findComment-6289244
Case Corsair Air 540 CPU AMD Ryzen 5 1600 GPU EVGA GeForce GTX 1080 SC2 iCX Motherboard Asus X370-F Memory G.Skill Flare X 16GB (2x8) 2400MHz Display Asus VG248QE Storage Samsung 960 Pro 512GB - Intel 730 Series 480GB SSD - 1TB Seagate Barracuda - 1TB WD Blue OS MS X Pro Peripherals Corsair K70 RGB Rapidfire -  Razer DeathAdder 2013
Case 15.4" Mid 2012 MacBook Pro CPU Intel Core i7-3720QM GPU Nvidia GT650M Memory Crucial 16GB (2x8GB) DDR3 1600MHz Display 1680x1050 AntiGlare Display Storage 1TB 5400RPM or Intel 730 Series 480GB SSD OS OS X Yosemite (Maybe El Capitan?) - BootCamp MS X Pro Peripherals Razer Blackwidow Ultimate 2014 -  Razer DeathAdder 2013 - Mionix Naos 7000 - Logitech K120 - Razer Tartarus Keypad
https://linustechtips.com/topic/468910-power-supply-for-sg13b/#findComment-6289249
Bit too pricy for my budget. $70 and below shall we say?
PSU is the one area where you don't want to sacrifice.
At $70 there really isn't anything that would be ideal for your needs. Shallow depth, modular, and decent quality.
My recommendation, drop your SSD until another paycheck, buy the SFX-L PSU. It's quality, shallow and fully modular with stock short cables.
EDIT: Postponing the SSD purchase will also give you time to pick out a better one.
https://linustechtips.com/topic/468910-power-supply-for-sg13b/#findComment-6289301
So no ATX PSU will work?
Also, what SSD would be better? I use an OCZ one but I heard the Kingston one was good too.
https://linustechtips.com/topic/468910-power-supply-for-sg13b/#findComment-6289378
Many will work, it's just far from ideal. If you were to buy a new 970, either Asus or Gigabytes ITX cards there wouldn't be an issue. It's just compensating for all the little issues that are present is not an easy thing to do with $70. There are a few units you could buy that would be shallow enough, and decent enough in terms of quality, but the cables would be an absolute mess and installation and maintenance later on would be miserable.
As for the SSD: http://www.anandtech.com/show/7763/an-update-to-kingston-ssdnow-v300-a-switch-to-slower-micron-nand
https://linustechtips.com/topic/468910-power-supply-for-sg13b/#findComment-6289721
I already own my MSI 970 so I can't do that. If you had to give me an ATX PSU what would it be?
https://linustechtips.com/topic/468910-power-supply-for-sg13b/#findComment-6289756
So I'm going to just go ahead and call myself an idiot. When I read SG13, I visualized the SG08. It's a very different internal design. That said, everything but what I said about GPU clearance still holds true. Just read SSD/HDD anytime a previous post mentions the GPU.
The 140mm length of the PSU you mentioned earlier is the shortest you can get without going SFX, which I still recommend, though is less important now I'm actually thinking about the right case. Though my recommendation for modularity still stands as important as ever.
If you can stretch your budget a little bit this would be the best choice I can think of.
As for alternative SSD's, here are some options. (They may not be the best, but they should be better)
http://pcpartpicker.com/part/kingston-internal-hard-drive-shfs37a120g
http://pcpartpicker.com/part/a-data-internal-hard-drive-asp900s3128gmc
http://pcpartpicker.com/part/a-data-internal-hard-drive-asp600s3128gmc
Also, there may actually still be some clearance issues with your GPU, nothing a dremel and vacuum can't fix, but your 970 is 0.09 inches long than the case can officially hold. There is often some leeway with internal measurements to allow some extra movement during installation, but you may have issues.
https://linustechtips.com/topic/468910-power-supply-for-sg13b/#findComment-6290005
I'll go for that PSU I guess, but I'm not overjoyed with the price. *sigh* the price I pay for quality...
Also, do you know if the OZC ARC 100 is any good? That's what I use in my home PC, and it seems fine (and cheap).
As for the GPU, the case specs lie; tons of people have fit an MSI 970 in that case.
https://linustechtips.com/topic/468910-power-supply-for-sg13b/#findComment-6290101
Also, thoughts on this? I know it's semi modular but that's not a big deal to me.
http://pcpartpicker.com/part/cooler-master-power-supply-rs550amaag1s1
https://linustechtips.com/topic/468910-power-supply-for-sg13b/#findComment-6290129
That will work very well.
As for the OCZ Arc, don't know anything about it.
https://linustechtips.com/topic/468910-power-supply-for-sg13b/#findComment-6290172
