Hi everyone, I need help with finding a solution for my home network. It's based on ADSL connection and runs at 40mbps download and about 4 upload. when im connected via ethernet cable or just sitting next to the router and using wifi, I get the speed i should, but the problem starts with my pc. it is a floor above the router and about 25 meters distant (on foot, aerial distance is about 6 meters). I bought the TP-LINK WA830RE range extender but i only get speeds of about 5 mbps that aren't enough at all. I don't want to rush and get PLC connectors so i want to consult first. I also need a solution for my brother's room, that is also complaining about the wifi (all he does is play a PS4 or surf the web on his phone).If more information is needed please ask, beacause this situation is intolerable.
Thank's in advance, and sorry if I have grammar issues.
TP-LINK WA830RE link: http://www.tp-link.us/products/details/cat-10_TL-WA830RE.html
https://linustechtips.com/topic/468612-adsl-problems/
Powerline ethernet?
Thats a s1ck connection for a adsl!
https://linustechtips.com/topic/468612-adsl-problems/#findComment-6285823
Get a powerline adapter or a better range extender. If the signal has trouble passing through your walls then there's not much you can do about it.
Also how do you have 40/4 ADSL? That's impossible.
he's probably confused
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/468612-adsl-problems/#findComment-6285967
