so im now using TES5Edit to clean all my mods up and I ran into a problem, loot says a mod has 2 ITM records and that I should clean with TES5Edit. but ive done the remove identical to master and the undelete and disable references thing and loot still says the message. so do you know what I have to do? Ive looked at the cleaning guide and I dont know, maybe im dumb but I couldnt findpost-249980-0-38066000-1445033660.png the answer
https://linustechtips.com/topic/468399-hardcore-skyrim-mod-cleaning/
so im now using TES5Edit to clean all my mods up and I ran into a problem, loot says a mod has 2 ITM records and that I should clean with TES5Edit. but ive done the remove identical to master and the undelete and disable references thing and loot still says the message. so do you know what I have to do? Ive looked at the cleaning guide and I dont know, maybe im dumb but I couldnt findattachicon.gifCapture.PNG the answer
Are you using a mod manager such as Nexus Mod Manager or Mod Organizer?
ya Mod organizer
Try deleting the mod this .esp is related to entirely and reinstalling it again.
