Straight to the point.
I've got a NFC tag few months ago and I've programmed it to unlock my phone whenever they both come in contact, so typically I kept the tag inside my wallet.
But quickly enough I've realised how annoying it is to take my wallet out whenever I want to check e-mails or facebook messages, so I thought about finding another solution..
Solution that would keep my phone secure as long as it's in my possession (ergo, in my range), but NFC lacks the neccessary range so I've had to look for something else.
Then I found RFID but I'm completely clueless whether it'll work the way I want it to work (the way NFC worked but with more range).
Which is - blocking my phone (via PIN or any other means) whenever it's out of RFIDs tag range, one that is located in my wallet.
So I was wondering - will it work the same was NFC worked? Is it as programmable as NFC? Are there any apps I could use for this certain thing?
Thanks for all the help in advance.
Desktop: ASUS Z97-AR | i7-4790K Devil's Canyon | ASUS GTX 980Ti STRIX OC | Corsair 650W TX | Corsair Vengeance - 8 GB 1600 MHz | Samsung Pro 840 - 256GB | SilentiumPC HE1225 | Cooler Master HAF-932 Adv. | Razer Deathstalker | Razer Taipan | SteelSeries DEX | SteelSeries Siberia Elite Black Prism Edition | DXRacer Maximum Series | Bluemic Snowball Aluminium
Laptop: ASUS Zenbook UX32LN
Camera: Nikon D5300
https://linustechtips.com/topic/467743-using-rfid-the-same-way-as-nfc/
umm attach it to a watch thus you just swipe phone on watch
I don't wear one.
Camera: Nikon D5300
Bluetooth unlock should work at those ranges.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
Bluetooth eats battery, a lot.
Camera: Nikon D5300
In the time it takes you to do all that you could enter a password/pin 5 times.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
The point isn't to unlock a phone - the point is to have it locked when I lose it.
Camera: Nikon D5300
I'm not saying it's perfect, but it would work in this situation.
I'm really looking more into using RFID - but googling 'using RFID for phone security' returns just places where I can RFID security cards for my employees.
Camera: Nikon D5300
If it's an Android you can lock the phone (secure lock), find the phone if gps is on and make it ring from Google device manager on a PC
