So.... I live in Norway. Shits expensive here... and while i CAN afford all of this with ease i "cannot" afford it (atleast if i want any money in my savings account)....
So... my current setup is in my signature for those wondering. The question and or dilemma i have is...
Fury X2 (Dual Fury)
or
Samsung 950Pro 512GB NVME M.2 SSD
or
EKWB Predator 360 AIO (i will later on also get a Predator 240 and a waterblock for whatever is my GPU)
what would you guys get?
https://linustechtips.com/topic/466490-a-tech-dilemma/
I see no reason to change anything for now.
^This.
That setup is completely fine, there is no need to change anything. Save the money so that when something comes out that you really want/need you have a good chunk of the cash there.
Other systems I've built:
https://linustechtips.com/topic/466490-a-tech-dilemma/#findComment-6259405
Fury X2 masterrace!
https://linustechtips.com/topic/466490-a-tech-dilemma/#findComment-6259406
Turnip has just as many supporters.
I am surprised to see that my build log name voting has a tie with turnip. Last time I checked at least.
https://linustechtips.com/topic/466490-a-tech-dilemma/#findComment-6259455
^This.
hahaha
money is never the issue here really. My upgrade itch and self control is :|
You have a 295x2.  There's no point in getting a Fury X2.
295x2 = 15-20% better then Fury X
when no CF = 30% worse then Fury X
My issue is the times when CF doesnt work.... Which leaves me at a serious disadvantage...
So my plan with the Fury X2 is so that when CF doesnt work, i still have a Fury X. Not a marginally OCd 290X
https://linustechtips.com/topic/466490-a-tech-dilemma/#findComment-6259477
hahaha
Exactly. Why do I have a 6 core i7 when an i5 2500 worked just fine? I... dont know....
https://linustechtips.com/topic/466490-a-tech-dilemma/#findComment-6259486
hahaha
I know the feeling :D
Still, nothing you really need to upgrade.
https://linustechtips.com/topic/466490-a-tech-dilemma/#findComment-6259487
With your current build, it looks like the only thing that may provide a noticeable improvement would be the Fury X2 though we don't really know the real capabilities of the FuryX2, just what AMD has told us.
The EKWB may be quieter than your current AiO, but with the stated expandability of the 360 that system can easily be the start of a custom loop.
So the real question is, what do you want to see in your case?
https://linustechtips.com/topic/466490-a-tech-dilemma/#findComment-6259739
i want to rebuild the whole rig if i could
but THAT would break the bank, litterally...
My case is my current gripe thought... that and the two 120GB + 250GB SSDs...
Case is cool af, but impractical beyond belief..... :|
SSDs are taking up both physical and SATA port space... need to upgrade those to something bigger or faster...
https://linustechtips.com/topic/466490-a-tech-dilemma/#findComment-6259845
